Tire question, 4 new on back axle?
Discussion in 'Experienced Truckers' Advice' started by Speedy007, Aug 13, 2017.
  1. Speedy007
    Speedy007 Bobtail Member
    13
    4
    Mar 21, 2007
    When on a tandem axle tractor, is it ok if tires on one axle are brand new and on the other almost worn?
    What im trying to get as is the difference in tires on the two axles a problem? Or is it safe?
  3. Roberts450
    Roberts450 Road Train Member
    2,237
    3,638
    Feb 6, 2016
    Its not the best but it's doable.
  4. Pedigreed Bulldog
    7,737
    14,424
    May 7, 2011
    It depends. If you're driving a Mack, and you've got Mack rears on it, then you need to keep all 4 corners about the same. If you're driving pretty much any other truck that has open differentials, then it doesn't really matter.
  5. Lazman
    Lazman Bobtail Member
    25
    14
    Aug 13, 2017
    I would place the 4 new on the rear rear axle and the 4 worn on the front axle so to make the worn tires last longer. I.e . The rear rear being your pulling axle from my own experience
    Diesel Dave and Dave_in_AZ Thank this.
  6. Espressolane
    18,711
    117,297
    In general, the recomended maximum difference between front and rear drives is 10/32. Will a large difference be a problem. Not that I have been able to determine from people who run like that. Having a big difference in the side to side I think is more of a problem
  7. uncleal13
    uncleal13 Road Train Member
    3,797
    6,299
    Apr 9, 2009
    Humboldt, Sk
    New tires on the rear axle tandem. Old tires on the forward tandem axle. Ideally no more than 8/32" difference in tread depth assuming tires are the same make and model.
  8. Speedy007
    13
    4
    Mar 21, 2007
    Thanks for the replies guys. Getting a truck from another guy and he has pretty much brand new lug tires on the back axle, half worn out on the front. You can notice theres a quite of a difference and was debating whether to replace the front axle or not. Seems like a waste of tires, so i think ill leave it for now if its not gonna be a problem
    Lepton1 Thanks this.
