Tire shops - advice required before going ballistic
Discussion in 'Trucks [ Eighteen Wheelers ]' started by blairandgretchen, Aug 26, 2023.
  1. AModelCat
    165,164
    Problem is he's got Budds, so the outer will have to come off to verify the inner.
  3. Last Call
    Last Call Road Train Member
    7,568
    45,914
    Mar 15, 2021
    I've changed alot of tires over the years .. I also have never torqued a lug nut ever just bust out the big air impact and hammer away.. never lost a wheel yet
  4. Rideandrepair
    17,578
    56,942
    Aug 8, 2015
    I wondered about that. Seems you could hit the inner, and if it were loose, it could be tightened, while the outer nut stays put, ( loosening it) Then the outer would need tightened.
    BoxCarKidd and bzinger Thank this.
  5. nikmirbre
    nikmirbre Road Train Member
    5,594
    10,373
    Jul 27, 2011
    High Point NC
    "Colored fella new to the area from Arizona"....... doesnt advance this story one bit....
    2Tap, ZVar, Chieftains and 4 others Thank this.
  6. Arctic_fox
    4,558
    25,946
    Sep 16, 2016
    This is why i carry my own torque wrench and impact..... About 1 lug in 20 moves usually. That said avoid that shop unless you have zero choice. Its like the manager of that store has you take an IQ test where you gotta put the blocks in the correct hole. However, unless you skip trying to fit them in the holes over directly trying to swallow the blocks instead while also flinging fecees at customers....your not hired.
    The one and only time i went there they forgot to put the lugs back on my wheels and had NO air in the tires.... then when i #####ed tried to give me this #### and bull story about how i drove in without lugs and tried to make me pay for a full new set instead of putting my own back on. Also told me it was $10 extra per tire to air them up....dispite having literally just bought 4 new tires.
    Place is a bad joke
  7. kylefitzy
    kylefitzy Road Train Member
    4,755
    19,811
    Aug 12, 2007
    Kansas city,Mo
    Good good the last paragraph is laughably stupid. I’d think I was on some sort of prank show.
    Siinman and Rideandrepair Thank this.
  8. SmoothBore
    SmoothBore Medium Load Member
    451
    709
    Jun 8, 2011
    The Desert
    what color? It’s Arizona, could be brown or black…
  9. Arctic_fox
    4,558
    25,946
    Sep 16, 2016
    Id thought i was as well but nope, they really are that dumb/greedy. There is a reason that shop has a....reputation. better then nothing but the helps quality varys from crap to government.
    Siinman, Rideandrepair and kylefitzy Thank this.
  10. SmallPackage
    5,818
    18,646
    Dec 20, 2019
    Marion Texas
    Reversing direction on a radial tire will not hurt a thing. That was a myth started up during the Firestone 500 recall during the late 70’s. They tried to blame failures on that practice during the many major law suits they had going on. ALL the mamufacturer recommend crisscross or swapping direction change on tires to flatten and smooth out the choppy heal toe wear they will develop. We swap Michelin and Bridgestone steers side to side and let them run against the sipes to smooth them out when needed. They have directional arrows so they will run arrows backwards.
    Milwaukee’s bad boy M18 impact gun can be custom programmed by them to a set torque stop for putting nuts on and still have full reverse torque for removal. Many shoos are doing this because its less tools to work with. Ingersal-Rand has had the same deal with their air guns for about 7 years now but we did handle a recall with them 3 years ago for over torque problems on one 1/2 drive model. The way the air guns work is if the line psi the gun is on is regulated at 90 psi the gun will only torque to 500 max. If the line psi is 120 or higher all bets are off.
    blairandgretchen, Feedman, 062 and 3 others Thank this.
  11. REO6205
    REO6205 Road Train Member
    13,168
    60,501
    Feb 15, 2014
    California.
    I asked our mechanic if he torques lug nuts when the truck tires are changed. He just said no, gave me that "mechanic look" and walked off mumbling to himself.
