tire size
Discussion in 'Ask An Owner Operator' started by the DD fan, Jan 12, 2024.
  1. the DD fan
    the DD fan Bobtail Member
    Lets say we have two trucks Both have same engines Same HP Same torque Same trans Same gear ratio but one truck has 11r22.5 tires and other has 11r24.5 tires will the truck with 11r22.5 tires pull better on hills If not what is the reason guys have 11r24.5 vs 11r22.5
  3. AModelCat
    164,645
    Ground clearance. 22.5 tires are too small out in the bush.
    Oxbow and Hammer166 Thank this.
  4. Hammer166
    7,605
    27,791
    Aug 18, 2007
    ~8600+' and loving it!
    The shorter tires have a lower effective gear ratio, so they will pull better with everything else the same.
    Oxbow Thanks this.
  5. uncleal13
    uncleal13 Road Train Member
    3,797
    6,299
    Apr 9, 2009
    Humboldt, Sk
    I had 11R24.5 pulling 140,000 lbs. switched to 11R22.5 looking for better fuel economy trying to run in what I thought was my engines sweet spot.
    Did find it pulled better, but fuel economy went down. So I switched back 18 months later when I wore out the drive tires.
    Yes, ground clearance is one of the reasons for oil patch and I went off roads into farmers fields.
  6. Cat sdp
    Cat sdp . .
    21,303
    76,192
    Apr 8, 2012
    Orion's Belt
    Isn’t the 24.5 16 ply rated for a little more weight than a 22.5 16 ply……
    plus less revolutions per mile …….
    Oxbow Thanks this.
  7. abyliks
    abyliks Road Train Member
    4,114
    9,682
    May 2, 2010
    ludlow MA
    11r 24.5s are a few pounds more then 1122.5s but 12r22.5s can carry more then 11r24.5
    Oxbow Thanks this.
  8. Brandonpdx
    Brandonpdx Road Train Member
    4,716
    4,839
    Dec 27, 2007
    Elkhart, IN
    Price and availability is also a factor. 24.5” rubber is not nearly as common. If that’s what size it has factory I’d consider switching between lo pro and talls depending on what the goal is, but replacing 10 wheels and tires at the same time would be an outrageous bill and probably not worth it.
    Cat sdp Thanks this.
  9. Cat sdp
    Cat sdp . .
    21,303
    76,192
    Apr 8, 2012
    Orion's Belt
    In the Northeast all the locals run them …..:)
    Oxbow and Ruthless Thank this.
  10. Cdemars316
    Cdemars316 Road Train Member
    1,028
    6,631
    Nov 10, 2018
    Switching over to 22.5's right now the cost is about the same with new rims, as it was for the last full set of 24.5's they are getting more expensive because there is less companies making them
    Oxbow Thanks this.
