Tire wear.
Discussion in 'Experienced Truckers' Advice' started by OFilippov, Oct 12, 2021.
  1. OFilippov
    OFilippov Bobtail Member
    40
    13
    Oct 2, 2014
    I got some weird tire wear on front left axle of my trailer. Inside tire looks worse than outside, but both thread wear on inside. Is that alignment issue?
  3. OFilippov
    40
    13
    Oct 2, 2014
    Rear axle looks better, but still signs of the thread wearing on inside.
  4. jason6541
    jason6541 Road Train Member
    2,425
    5,366
    Mar 5, 2012
    Omaha, NE
    Have you checked for loose bearings or
    Are you running heavy and possible axle flex?. Is it all around the circumference of the tires?
    Weird that the outer one inside edge is wearing that way. Was it possibly on the inside wheel position?
  5. bonder45
    bonder45 Road Train Member
    1,803
    5,452
    Oct 2, 2011
    Williston, ND
    Also, check your shocks - see if they're shot.
  6. Arctic_fox
    4,520
    25,573
    Sep 16, 2016
    Check the main bushings as well. Mine did exactly the same thing and it turned out the suspension bushings were shot.
  7. OFilippov
    40
    13
    Oct 2, 2014
    Not sure if I have shocks on this trailer. Only see airbags and some like limiting chains. Sorry not a pro here.
  8. OFilippov
    40
    13
    Oct 2, 2014
    Not sure how to check the bearings, but don't see nothing obviously wrong in there.
    Always legal weights - nothing super heavy. Don't remember having nothing more that 33k there.
    Actually just went back there and checked again. It is not all around circumference of the tire. Probably the only one that's goes all around is the worst one (FLI) the other tires actually do look perfect in some spots and eaten away in other spots.
    I did not rotate the tires - so they are at their original positions.
  9. OFilippov
    40
    13
    Oct 2, 2014
    I'm at TA right now. Asked them at service desk. They said ether shocks or alignment, but don't have an alignment machine at this location.
    D.Tibbitt Thanks this.
  10. D.Tibbitt
    157,227
    I would try to find a good alignment shop to take care of it. Anywhere is better then a truckstop
  11. little cat 500
    2,061
    1,109
    Jan 17, 2010
    Abbottstown PA
