To 2014....and BEYOND!!!!
Discussion in 'Trucks [ Eighteen Wheelers ]' started by PeteSalesGuy, Sep 21, 2012.
  1. PeteSalesGuy
    PeteSalesGuy Light Load Member
    81
    56
    Aug 27, 2012
    Buffalo, NY
    While it is not yet 2013, the 2014 emissions regulations will be showing up in the 2013 engines from most manufacturers. In fact Peterbilt has started building trucks equipped with 2014 level engines on a "ramp up" basis.
    The 2014 emissions are "greenhouse gas" based i.e. manufacturers (truck makers) must start reducing the Grams per Mile of the greenhouse emissions and to do this they are tasked with several challenges. First the percentage of DEF used will increase from the current 2-4% to 4-6% percent of fuel burned. As current DEF useage is dependant upon load, type of driving, etc. the point is the DEF useage percentage will go up 2-3% over current levels in a comparable use situation. The upside? Engine manufacturers expect an equal or greater increase in fuel mileage so net cost will be offset or improved. There are additional sensors in the DPF/SCR units to measure DEF quaility (Thank International and their lawsuit....of course now THEY are going SCR...go figure!) as well as sensors to measure the ammonia level as the DEF degrades in the SCR and to measure emissions before the tailpipe, this will allow the computer to adjust and keep the gases in specification.
    The 2014 engines are tuned to cruise at lower RPMs, the sweet spots are 100-250 lower than current setups and of course gearing will be adjusted accordingly. I would expect to see taller rear ratios and more direct top gears to reduce the drivetrain drag losses that overdrives have.
    There is a fuel mileage standard that the federal government is phasing in to take full effect by 2017 model year. The net goal is 10 MPG for a road tractor at 80K gross. This will require powertrain improvements, aerodynamic improvements, tire resistance improvements, etc. There will be a "points" system and manufacurers must meet a points goal to avoid fines of up to $30,000 per truck. Vocational trucks (i.e. dumps, etc.) will have the lowest goals with type of use determining what goals must be met. Highway tractors have the highest goals. Maunfacturers can start earning points to bank now by selling fuel efficent tires on rigs, aero packages, etc. This will allow manufacturers to "bank" points to apply against units that will not meet the standards.
    The bottom line to you? Expect less choice in tires, ratios, and such. There is a good chance road tractors will be shipped with a 65 MPH limiter....a hard limiter that cannot be turned up by a dealer! APUs will be virtually mandatory to purchase on most sleeper tractors, aero skirts and such will be required. And for all of those "long and tall" fans you will likely see the end of the traditional style tractor. Possibly no more 389s, Freightliner Classics, etc. if it can't meet the aero drag standards, it will likely not be offered as it will drag down the points of the manufacturer.
    Fair warning, the times they are a changing (apologies to Dylan) and those who will not change with them will be left on the side of the road.
  3. Semi Crazy
    Semi Crazy Road Train Member
    3,033
    2,047
    May 13, 2011
    Middle Tennessee
    So you're talkin' about a truck that costs upwards of $150,000.00 and spends 3 months out of the year in the shop!
    Do glider kits factor into the points equation? I think less said about them on the internet the better. Some gov't bureaucrat will learn about them and propose to "close the loophole".
    alaga and GrowinupMX Thank this.
  4. alaga
    alaga Light Load Member
    195
    62
    Jan 9, 2012
    Fayetteville, GA
    One of my neighbors is a tech at a local dealership and has told me that DEF will not be used past 2015 - is this true? I don't have to have it, but this technology and its associated hardware (be it bad or good) is only a couple of years old (here in the States) and will possibly be obsolete? How idiotic is this?
    And more discussion of speed limiters? My rant could turn political very easily...
    freightliner438 Thanks this.
  5. PeteSalesGuy
    81
    56
    Aug 27, 2012
    Buffalo, NY
    Unless there is radical breakthough by then, DEF is here for the foreseeable future.
  6. PeteSalesGuy
    81
    56
    Aug 27, 2012
    Buffalo, NY
    No, so far Gliders are not part of this.
  7. dieselroarmt875b
    dieselroarmt875b Medium Load Member
    315
    58
    Aug 26, 2008
    YOURAPEEIN
    looks like the double clutch transmissions and longer rear axle rations will be the next trend in trucking
  8. aiwiron
    aiwiron Road Train Member
    5,927
    5,228
    Aug 24, 2011
    Sunny Tampa Florida
    I foresee people hanging onto older trucks.
    VARITHMS, w900, reiffy85 and 1 other person Thank this.
  9. Pablo-UA
    Pablo-UA Road Train Member
    7,604
    1,642
    Oct 11, 2010
    Borispol, Ukraine
    this is the European way. All EU trucks are speed governed. and it is really hard to change limits on many EU trucks..
  10. mph1972
    mph1972 Light Load Member
    199
    42
    Sep 2, 2012
    Johnsonville, SC
    It will be interesting to see what does come from all of this. I grew up with a dad that was in the industry for years and after I retired from the Navy (January 2012) I am now coming into the industry and talking with my dad on the little I know of it, he is sort of surprised at the changes that have been made over the last 15 years. I personally do like the mandatory APU (or equivalent) idea. I certainly hope the PETE 389s and Frieght XLs don't become a thing of the past, I still think the 379/389s are the best looking trucks on the highway.
  11. rollin coal
    rollin coal Road Train Member
    13,707
    28,224
    Mar 29, 2008
    TN
    If the mandated 10mpg thing comes to pass gliders will never be a viable alternative. 2017 and up trucks will be getting 10mpg+ as a matter of routine. Rates will go down across the board accordingly. 5, 6, 7, 8 mpg won't cut the mustard anymore. Really rediculous that the government is mandating this adding huge cost burdens. Left alone manufacturers would likely get there at some point anyways. Didn't realize the 10mpg mandate was written in stone yet though, just thought that was something they are pushing for?
