To in-frame or not?
Discussion in 'Ask An Owner Operator' started by 5thwheel23, Dec 5, 2011.
  1. 5thwheel23
    5thwheel23 Light Load Member
    82
    22
    Jun 5, 2010
    South carolina
    wel i was wondering what yall would do. would you you buy a truck with 6 or 700,000 or more miles on it for 20+k or would you get a cheap truck with 1M+ miles on it and do an inframe on it. thnks for the replies in advance, and i know that there are alot factors that wld come into play but just think of it as a hypathetical question.
  3. Okieron
    Okieron Crusty Okie
    1,641
    1,024
    Dec 23, 2009
    muskogee, ok
    An in frame only covers the motor, what about trans rear ends or suspension and frame. all of those can add up real fast a clutch is over a thousand a trans is several thousand. Just my 2 pennies
  4. RickG
    RickG Road Train Member
    12,812
    6,137
    Jul 22, 2008
    Owensboro , KY
    When you buy a million mile truck think of all the components besides the engine that have that many miles on them . The age of of the truck may also further limit job opportunities
  5. blackw900
    blackw900 The Grandfather of Flatbed
    5,817
    7,678
    Jul 12, 2009
    A.W.O.L
    Any company that won't take an older truck is not worth working for....
  6. kajidono
    kajidono Road Train Member
    6,422
    4,659
    Jun 1, 2009
    Streetrat
    I probably wouldn't unless I had a trusted mechanic lined up to do it. The guy we're leased on with has a semi retired mechanic that used to work for Cummins working for him and owns his own tow unit, so that's what he does. He'll find a truck over here, an engine over there, a transmission over here, and go get it all himself for his guy to put together for him.
    20k is high, though. He'll go find one for $6k and go from there. And even then the mechanic will tell him whether it's worth messing with or not. You can't just buy any old thing because it's cheap. You have to know what you're looking for.
  7. 5thwheel23
    82
    22
    Jun 5, 2010
    South carolina
    right i get what all of you are saying. i apreciate it. i am just wondering what the best bet to do is.i want a good strong running truck just like every other driver. just wondering what the best option is with not having good credit. i want to try to keep the cost down as much as posible. i really dnt care if the truck looks the best i just want something that runs great and can make money without paying out the rear.
  8. Wildcat74
    Wildcat74 Medium Load Member
    354
    128
    Jul 15, 2008
    Omaha, NE
    I would say the best way to go lies in the middle somewhere. Get a truck that is a little long in the tooth but not completely worn out that you can go to work with and then with a little luck you'll be able to keep the thing maintained and running as you work.
  9. Oscar the KW
    Oscar the KW Going Tarpless
    12,247
    28,120
    May 19, 2011
    Maintenece records. I would not hesitate to buy a truck that was in good condition with maintence records that has a million miles. Transmission, rearends can last over two million miles if maintained and driven properly. Plus those trucks are usually cheap. You can find them inframed already for less than 20k.
  10. Blind Driver
    Blind Driver Road Train Member
    3,081
    1,406
    Aug 7, 2006
    New Albany, IN
    You'll have to replace all of the little things.
    I'm looking at a '93 T600 with tons-o-miles on it. The 3406 had been rebuilt a few years ago.
    I know this truck needs all the rubbers in the suspension replaced. All 8 air bags are showing cracks, and the shocks are worn out. I'll probably start replacing all of the braided fuel lines, belts, hoses, thermostat, fluids, and inspecting everything electrical. I'll also assume the clutch is on it's last leg, but I'll keep my fingers crosses for the time being.
    Ill also need to inspect the wheel bearings.
    On a positive note, the frame shows no rust and is still powdercoated. The hood, cab, and sleeper are damage free, but the cab extenders are trashed. The side skirts could use a bit of TLC.
  11. SHC
    SHC Spoiled Rotten Brat O/O
    8,484
    7,047
    Feb 26, 2011
    Westville, IN
    Get ready for disappointment. This is trucking and stuff breaks. That 700k mile truck could need a rebuild before that million mile truck. Maintance records and paperwork is the key to buying a good used truck. Without records it isn't even worth the minutes on your cell phone.
