Too good to be true!
Discussion in 'Volvo Forum' started by BobcatVolvo, Mar 9, 2014.
  1. BobcatVolvo
    BobcatVolvo Light Load Member
    171
    132
    Feb 23, 2014
    Western Ohio
    Well, either I have a problem or Volvo Jesus blessed my truck last night. I just ran over 300 miles and the fuel gauge on my 08 880 haven't moved a bit. I can used the old odometer/calculator method to make my deadhead home run, but what do you guys think will be the easiest/most likely problem to check first?
    Of course, if I'm really getting infinite fuel mileage, I'm not going to complain.:biggrin_25525:
    Puppage Thanks this.
  3. baby
    baby Light Load Member
    132
    64
    Feb 27, 2014
    Charleston, WV
    Your float is BROKE. Probably. But God bless you! My Volvo is in the shop AGAIN because the steering wheel is BOUNCING.....
    BobcatVolvo Thanks this.
  4. Stile
    Stile Heavy Load Member
    933
    668
    Mar 8, 2014
    I'd trade a broken float and a bouncing steering wheel any day for the blown head that put a hole in my 780's engine block the size of a basketball. :)
  5. baha
    baha Road Train Member
    4,137
    2,837
    Jul 25, 2013
    ga
    Use a stick to gauge the level in tank.
  6. BobcatVolvo
    171
    132
    Feb 23, 2014
    Western Ohio
    Amen to that. I'm not going to complain too much, I have been very lucky on this truck (so far.). It's only spent a few unplanned hours, and less than $1500 in the shop in the 3 years I've had it.
    Stile Thanks this.
  7. BobcatVolvo
    171
    132
    Feb 23, 2014
    Western Ohio
    Saint Volvo apparently fixed it, either that or I was burning 5 gallons a mile the last 20 miles into home. I checked it with a stick when I pulled into home, so apparently something broke loose. Probably a leaf or stick from the pump at the T/A. I will keep an eye on it for awhile.
  8. Dickeyroberts
    Dickeyroberts Light Load Member
    138
    30
    Feb 23, 2014
    I just now had the same problem. I too was getting excited but I took my fuel cap off to check and the chain on the fuel cap was tangled up in the float. Could be your problem
  9. BobcatVolvo
    171
    132
    Feb 23, 2014
    Western Ohio
    I checked it again today, and it was fine. I guess that was it. I thought maybe Volvo had solved gas mileage with tiny nuclear reactors or something.
  10. terryt
    terryt Heavy Load Member
    736
    777
    Apr 27, 2009
    the valve that equalizes the tanks is going bad on the return line allowing more fuel to return to just one tank.
