top load vs center load antenna
Discussion in 'CB Radio Forum' started by fgb3, Dec 18, 2011.
  1. WA4GCH
    WA4GCH Road Train Member
    3,324
    577
    Aug 12, 2009
    Seminole Florida
    AGREE !
    It is a nice test however the information need to have a common base to give someone a real idea of what the gain or loss is ...
  3. AB7IF
    AB7IF Light Load Member
    205
    103
    Jun 11, 2011
    Somewhere, Ar
    Assuming the correction factor varied by say 10 percent, and two models showed a 30 percent difference, one could assume the better signal was at least 20 percent better or more so therefore the signal was improved. For example no matter how bad the initial test conditions were I am positive a Wilson 5000 outperforms a coat hanger.
  4. Rat
    Rat Road Train Member
    My results are from using different antennas on the truck I run. I have tried many different antennas to get the best performance. One thing is that tuning fiberglass sticks is not as easy as a whip style antenna and yes they have to be tuned also.
    There is no such thing as a plug and play antenna. Fiberglass antennas usually require cutting the fiberglass along with cutting the wire. If you cut too much then you are buying a new antenna. Were a whip style it is not the case. The upper whip can be moved up and down to a degree. You might have to cut some of the upper whip off but you really have to cut alot off before you loose adjustment.
    Ice buildup on whip styles will not harm them. Ice buildup on a fiberglass will cause it to snap off.
    Now for performance. My wilson 5000 brings is more signal then any fiberglass I have used. Meaning I can hear people better with the Wilson. Also people can hear me better using the wilson even after spending alot of time tuning the fiberglass antennas.
  5. mike5511
    mike5511 Road Train Member
    3,154
    1,544
    May 15, 2011
    NW Arkansas
    I prefer my wilsons also. I just use the Francis because it works good enough and is cheap to replace. If you remember, I slip seat so I'm only concerned with "good enough". With these new trucks, it takes time to get an antenna "right", and I don't have that luxury.
    bubba T Thanks this.
  6. V8Lenny
    V8Lenny Road Train Member
    1,016
    130
    Aug 3, 2008
    Europe
    It was not the first time when Wilson didn't win. Don't believe the ads. Fiberglass antennas are better in theory and practice.
  7. fgb3
    fgb3 Light Load Member
    112
    36
    Nov 2, 2011
    elba ny
    Hey Mike 55 you said you drive cascadias right? Or used to? I believe you are the person that told me about the mount from Walcotts. Well that's the mount I have and am running a Wilson 5000 with 10 inch shaft from that. The question I had which was better was because of how low it is mounted on truck. I was actually going to buy myself a new Predator 10k (it is christmas you know lol). Now the question is will it benefit my set up? I saw on their website that they have one with a 27 inch shaft but shorter stinger. Will this work good(27 inch also gets the "load" part up higher) or is that a waste of money? Do I NEED a top mount? Thanks guys
  8. Smaggs
    Smaggs Pie Crust
    1,405
    698
    Apr 12, 2011
    Pittsburgh, PA
    So I guess the better test would be different antennae, but matched, grounded, mounted and calibrated equally as well?
    Can Fiberglas handle amplifier heat as well as metal? What about flex factor in high winds.
    I have stock Volvo antennae. Two. The black ones with the copper looking wire in them. Don't know anything about them. I hear well and get out strong with my east coast amp
  9. Smaggs
    Smaggs Pie Crust
    1,405
    698
    Apr 12, 2011
    Pittsburgh, PA
    I want to get one or a pair of antennae. With all the mixed reviews, I don't know what to get.
    I have my eye on the black K40 6000 watt antenna... That, or the 5000 Wilson.
  10. fgb3
    112
    36
    Nov 2, 2011
    elba ny
    I think I'm gonna try the "Bad to the Bone" by preditor 10. Its 6 feet long and that's with a 17 inch shaft. That's longer than my wilson and the load is up 7 inches higher ill let you guys know how it works thanks everyone
  11. V8Lenny
    1,016
    130
    Aug 3, 2008
    Europe
    Fiberglass antennas have usually a lower power rating than steel whips. But anything over 500 Watts is useless anyway and most fiberglass antennas can take that.
    I read somewhere that because fiberglass don't swing at high winds they perform better.
    Smaggs Thanks this.
