top load vs center load antenna
Discussion in 'CB Radio Forum' started by fgb3, Dec 18, 2011.
  1. Smaggs
    Smaggs Pie Crust
    1,405
    698
    Apr 12, 2011
    Pittsburgh, PA
    I don't know what this means.
  3. Smaggs
    Smaggs Pie Crust
    1,405
    698
    Apr 12, 2011
    Pittsburgh, PA
    Okay... I did something and wanted to share my results.
    I purchased two pairs of antennae. Firestick 4" with the tunable tips and the K40 black antennae with the center coils (the 5000-6000 watt ones).
    I installed the K40s and could not get an SWR below 3.
    I installed the Firesticks and my SWR is between 1.5/1 and 1/1 ratio, so I'm sticking with them.
    I'm using the stock Volvo antennae mounts, coax and everything. The antennae that were stock on my truck got an SWR of almost 2.5/1 which is unacceptable...
    So far, I've been having great results with the firesticks... I even noticed that my reception is much greater. I was having trouble just hearing drivers that weren't right next to me, even with my RF gain cranked, I was mostly getting static.
  4. WA4GCH
    WA4GCH Road Train Member
    3,324
    577
    Aug 12, 2009
    Seminole Florida
    TOP loaded antennas TEND to work better ... Firesticks and HAMSTICKS are top loaded. NOW that said there is nothing WRONG with center or even bottom loaded antennas but I will go with top loaded if I have the choice.
    rabbiporkchop and darthanubis Thank this.
  5. WA4GCH
    3,324
    577
    Aug 12, 2009
    Seminole Florida
    :biggrin_2556: INTERESTING :biggrin_2556:
    But maybe true I've never seen data either way ....
  6. The Bulkmatic Grasshopper
    The Bulkmatic Grasshopper Bobtail Member
    40
    17
    Apr 4, 2012
    Kentucky
    I just have the driver's side using the factory Volvo coax & mounts (had two 4.5' Francis until the passenger's side broke). I ran the Francis 4.5' Hot Rod for a while and had an SWR of 2.0:1.
    I switched to a K40 Plus (that I got on clearance at a Pilot) and have yet to get above a 1.5:1 SWR
  7. x#1
    x#1 Road Train Member
    1,773
    1,104
    Dec 24, 2009
    Cherokee County, Alabama
    I AGREE but the francis antennas of today do not seem to last any where near as long as the ones of old.I will still continue to purchase them however as they are sooooo simple and of relative LOW swr.period.
    rabbiporkchop Thanks this.
  8. Anthony Cowens
    Anthony Cowens Bobtail Member
    Aug 17, 2014
    I have a 2012 Volvo truck with mirror mounted antennas 2ft tall,made by Rami aircraft technogies. I am getting out around 4 to 5 miles now. I Have tried to get out farther with the Firestick adjustable top load, & the Wilson 2000 and I experienced drop at around 2 to 3 miles.All of my antenna setups have been lower than 1.5 swr measurements on channels 1,20,30,&40, but the factory Rami antenna still beats them all and I believe it is because of the aircraft technology built in. I have a Cobra 29 that has only been peeked and tuned. So now I am going to stick with Rami aircraft technogies and I have installed 2-42 inch antennas. Plus Rami fiberglass antennas are tested and tuned on trucks. The new 2014 Volvos come with the longer 42" antennas and should have a rating of 6 to 10 miles. ( no specs on Web page) I should be getting out around 6 to 7 miles already. And I hope the longer antennas will max me out! Wish me luck! Either way, Rami out performs Wilson 2000, and Firestick for factory screw in mirror antennas. This has been a expensive journey, but I am learning about good and bad cb equipment in the process to compare to other websites. If I decide to upgrade I won't go over 500 watts anyway because my next purchase will be a 10 meter galaxy with a peek and tune to get me at 100 watts, and out to around 15 to 20 miles hopefully. I am in the back woods sometimes, and no cell service is why I started this adventure!
  9. generallee
    generallee Medium Load Member
    512
    441
    Jan 4, 2014
    WoW! I have never seen so much BS being passed off as fact in one place as I have when reading thru this thread. The amount of ignorance from people claiming to "know" what they're talking about is nothing short of mind boggling.
  10. MsJamie
    MsJamie Road Train Member
    It's a trucker's forum; what did you expect?
  11. darthanubis
    darthanubis Heavy Load Member
    825
    616
    Jun 26, 2015
    And this is your "contribution"?
    slim6596 Thanks this.
