Torn blue plastic coating on driveline splines
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by mile marker 27, Feb 29, 2024.
  1. mile marker 27
    mile marker 27 Road Train Member
    1,419
    1,739
    Dec 4, 2019
    Plastic coating is torn on my rear driveline’s splines. It’s made it extremely difficult for it to slide. What to do?
  3. BoxCarKidd
    BoxCarKidd Road Train Member
    4,556
    6,645
    Aug 26, 2014
    We run them as long as they do not have excessive side play.
    Rideandrepair and mile marker 27 Thank this.
  4. Smellfunny
    Smellfunny Road Train Member
    1,446
    967
    Jan 28, 2012
    South Carolina
    The best thing to do would be have the old one cut off and then to have a new stub shaft welded on to the end.
    mile marker 27 and Diesel Dave Thank this.
  5. uncleal13
    uncleal13 Road Train Member
    3,797
    6,299
    Apr 9, 2009
    Humboldt, Sk
    I took mine apart and put in fresh grease to make sure it didn’t seize.
  6. Last Call
    Last Call Road Train Member
    7,568
    45,914
    Mar 15, 2021
    That blue coating is basically like teflon but heavier if it’s torn it’s because there is excessive wear in the splines
    You have 2 options 1 grease or anti seize the slip joint and run it till it tears things up which might be next week or 10 years
    2 replace slip joints now
