Torque specs for Volvo shocks
Discussion in 'Volvo Forum' started by proven23, Mar 28, 2019.
  1. proven23
    proven23 Bobtail Member
    5
    Hi, everyone. I'm trying to change the shocks by myself and wanted to know the torque specs on Volvo VNL shocks bolts.
  3. PureLeafTea
    PureLeafTea Light Load Member
    271
    490
    Mar 21, 2013
    Honestly I don’t think anyone worries about it. Every time I have had it done (because why I don’t know - I can NEVER get the bolts loose with my big air compressor and impact!) the mechanic just tightens them down with the impact. I’m sure technically there is a torque value, but I don’t know it.
    Socal Xpress and proven23 Thank this.
  4. proven23
    5
    I guess that's what I'm going to do if I can't get the numbers thanks for your reply
  5. Ridgeline
    22,741
    123,671
    Replace the bolts when you do the work, torque them tight.
  6. AModelCat
    164,923
    Brap braaaaaaapppppp!!!!!!
  7. QUALITYTRUCK
    1,819
    1,783
    Jun 14, 2009
    romulus,mi
    I just looked it up and that is the exact torque specs. for shock bolts. Strangely enough it's the same for all of the truck manufacturers.
    AModelCat Thanks this.
  8. boneebone
    boneebone Road Train Member
    2,297
    2,372
    Mar 13, 2009
    The nuts on the bolts are usually self locking so if you tighten them down to at least 100 ft lbs you should be fine.
  9. boneebone
    2,297
    2,372
    Mar 13, 2009
    You must have a weak compressor or air impact as I can loosen them with my Matco cordless impact with 1300 ft lbs of reverse torque.
    The only time my impact wouldn't loosen them up was when the bolts and nuts were seized from rust on my friend's truck and I had to get the torch out to heat up the bolt, and that was after he took it to two different shops and they tried with their air impacts.
  10. Newto Trucking
    Newto Trucking Medium Load Member
    359
    226
    Dec 26, 2013
    NE Illinois
    M16: 220+-35 Nm ( 162+- 26 ft-lb ) Grade 8.8. Use some anti seize on those bolts so much easier to remove them later.
