Torque uprate vs transmission
Discussion in 'Trucks [ Eighteen Wheelers ]' started by Xzachtly, Dec 2, 2018.
  1. Xzachtly
    Xzachtly Bobtail Member
    21
    24
    Feb 10, 2018
    Illinois
    I’ve been doing some research and can’t seem to find any conclusive answers to my question. I have a Kenworth with a Cummins n14 plus running into a Rockwell 9 speed (RMX 9 155B). Truck sits on tall 24.5s and has a 3.91 rear ratio. Right now it’s tuned to 525hp 1590 ft/lbs and just doesn’t hold in the hills. Is there any likleyhood of the 9 speed holding up with a 1850ft/lb tune? Obviously can’t be stomping on it at the pedal but I don’t usually drive heavy anyway.
  3. DL550CAT
    DL550CAT Road Train Member
    1,427
    1,482
    Oct 18, 2009
    Waynesburg, Pa
    My last truck had an 1850 rated trans and well over 2000 lbs of tq. It was not uncommon to gross over a 100,000. I run it for years that way with out issue.
    I never put it to the floor on the low side of the trans when I was loaded.
  4. tnevin225
    tnevin225 Road Train Member
    1,166
    1,601
    Jan 1, 2014
    Have you thought about doing a 13 speed conversion on it also, if it's possible on that model. would help with holding the hills better.
  5. Bakerman
    Bakerman Road Train Member
    4,663
    8,812
    Jan 27, 2013
    Phoenix, AZ
    I was told there is no difference internally between the 1850 & 2050 tq trans, the extra expense is for the warranty.
    Check you clutch size, as that may be a limiting factor.
    062 Thanks this.
  6. Dirty Britches
    Dirty Britches Light Load Member
    101
    431
    Dec 1, 2018
    It will hold up fine. Just don’t snatch gears.
  7. Xzachtly
    21
    24
    Feb 10, 2018
    Illinois
    I had my local shop check into converting it...they said it wasn’t possible on this model. Eventually I want to put a fuller 13 or 18 in it, it’s not in the budget right now though.
  8. T800H
    T800H Medium Load Member
    608
    295
    Apr 2, 2010
    The Keys
    It will hold up mine is rated at 1650 and my engine is close or over 800 hp been like that since 2010 not a single problem.
  9. snowman_w900
    4,418
    81,024
    Nov 25, 2010
    For the most part that's true, but there is a slight difference in gear hardening on the gear sets between a RTLO 16xxx versus RTLO 18xxx versus RTLO 20xxx transmissions. That's about it really. Bearings and internals are all basically the same.
    SAR and Bakerman Thank this.
