Totes. First time using my tanker endorsement
Discussion in 'Tanker, Bulk and Dump Trucking Forum' started by Qbf594, Nov 4, 2020.
  1. Qbf594
    Qbf594 Road Train Member
    1,642
    8,715
    Aug 15, 2019
    Southern Canadian annex, NY
    Any suggestions on my morning load of fertilizer in totes?
    I passed the computer test ages ago. Never been hooked to a tank so this a new experience...
    Wasted Thyme Thanks this.
  3. RockinChair
    RockinChair Road Train Member
    5,396
    14,516
    Feb 19, 2012
    Lubbock, TX & thereabouts
    Make sure they're strapped down really well.
    Accelerate gently, brake gradually, and slow way down for curves and turns.
  4. motocross25
    motocross25 Road Train Member
    3,889
    11,949
    Sep 23, 2010
    Overland Park, KS
    @RockinChair nailed it. Along with his advice, a nugget of information I can offer is make sure they know how to load them so the weight is distributed evenly. Your probably lookin at a ton or more per tote. I’d usually go single, double, single then double back. Obviously this depends on how many you get. You’ll be alright. Just take your time. Oh! If they do nose load all of them, and you hafta drop your trailer, slide your tandems all the way to the rear before you get out from under it to prevent a nose dive.
  5. Qbf594
    1,642
    8,715
    Aug 15, 2019
    Not on a deck, in a reefer. But yes I have straps and a couple of bars to put behind them.
    RockinChair and motocross25 Thank this.
  6. Qbf594
    1,642
    8,715
    Aug 15, 2019
    Ohhh, thanks I might be relaying....
    homeskillet and motocross25 Thank this.
  7. Rugerfan
    Rugerfan Road Train Member
    7,754
    39,755
    May 3, 2011
    Redding,CA
    Not too much to it. You’ll probably feel some surge. Give yourself a little extra more time to stop for lights and what not.
    MACK E-6, D.Tibbitt and Qbf594 Thank this.
  8. Dave_in_AZ
    426,094
    Hazmat totes you're supposed to have a strap on every tote.
    12 totes, 12 straps. To the side of the trailer.
    That's minimum.
    We had several guys fail inspections, and several shippers are requiring 2 on every tote.
    I've had DOT cut the cable seal and climb through the trailer.
    May The OM be with you.
    homeskillet, MACK E-6, magoo68 and 3 others Thank this.
  9. Just passing by
    Just passing by Road Train Member
    1,176
    3,140
    Feb 25, 2017
    Make sure straps DO NOT touch plastic or the lid of tote. Friction might damage them. Take it easy on the driving, pretend there's a three tiered wedding cake back there.
    MACK E-6 and Qbf594 Thank this.
  10. REO6205
    REO6205 Road Train Member
    13,168
    60,500
    Feb 15, 2014
    California.
    Check the totes for leaks, damage that compromises the structure ,and make sure all the fill spouts and drain spouts are snug.
    Any leak, and I mean any leak of any amount, is a haz-mat violation and will cost big bucks.
    magoo68, Midwest Trucker and Qbf594 Thank this.
  11. Tb0n3
    Tb0n3 Road Train Member
    4,738
    9,654
    Oct 5, 2012
    Earth
    Is all fertilizer hazmat? The OP didn't specify, and it sounds like they're not expecting hazmat. I've only hauled totes once and it was temp controlled latex paint base. That stuff didn't surge or anything. It might just be my driving style though.
    One note that may not be obvious is, the more full they are the less surge you'll get. If they're half full it might be fun.
    Qbf594 and Just passing by Thank this.
