Tractor parking brake.
Discussion in 'Ask An Owner Operator' started by Ikamob01, Sep 15, 2022.
  1. Ikamob01
    Ikamob01 Medium Load Member
    314
    195
    Dec 4, 2021
    Tractor parking brake not working when I pull the yellow knobs. Or working but takes a while.
    So where should I start the diagnosis?
  3. supergreatguy
    supergreatguy Road Train Member
    1,030
    2,896
    Nov 26, 2020
    check for bad wires. Start from lights and go up
  4. Ikamob01
    314
    195
    Dec 4, 2021
    Bad wires? It doesn't have wires.
  5. InTooDeep
    4,981
    37,363
    Jan 17, 2016
    Carmichael CA
    :biggrin_25523:
  6. AModelCat
    164,923
    Check spring brake relay valve and/or quick release valve. Might be sticking and not dumping air fast enough.
  7. Ikamob01
    314
    195
    Dec 4, 2021
    It stopped engaging, do you know what it looks like or where it might be located?
  8. '88K100
    '88K100 Road Train Member
    1,494
    3,624
    Aug 23, 2020
    Twice on current truck the parking brake for tractor and trailer would not operate,,,learned this as I was stepping out of truck.(this was at the top of a 2 mile 5% decline:eek:) Not sure what the shop did. On a grade I always wait a few seconds before exiting to make sure both brakes apply.
  9. Ikamob01
    314
    195
    Dec 4, 2021
    How did you solved it or changed it?
  10. SmallPackage
    5,813
    18,627
    Dec 20, 2019
    Marion Texas
    If taking awhile to exhaust air to apply springs then i’d look for a line restriction, bad quick release valve, or plugged exhaust in dash valve or quick release valve.
    If exhausts air and applies springs like normal but takes awhile for shoes to grab and lock down drums to stop a rollaway. I’d look at possible broken springs in chambers, bad slacks/ or out of adjustment, camshafts defective, lack of grease or grease turned to glue, shoes and drums beyond service size and wear tolerances or getting oil contamination.
  11. Ikamob01
    314
    195
    Dec 4, 2021
    On
    If it exhaust air it does apply brakes. If I park it doest apply brake.
