Tractor will not detach from trailer
Discussion in 'Questions From New Drivers' started by BukowskiFlowers, Dec 5, 2018.
  1. BukowskiFlowers
    BukowskiFlowers Light Load Member
    60
    23
    Jan 24, 2017
    I've tried raising and lowering fifth wheel, going back and forth but it won't come loose.
  3. truckdriver31
    6,998
    8,363
    Sep 18, 2013
    hey thats a good thing
    RedRover, Kyle G., Lepton1 and 3 others Thank this.
  4. Vic Firth
    Vic Firth Road Train Member
    1,843
    4,303
    Jan 19, 2016
    Indiana
    Do you have a manual release or pneumatic air cylinder?
    BukowskiFlowers Thanks this.
  5. truckdriver31
    6,998
    8,363
    Sep 18, 2013
    but really is it cold where you are. lower legs down too they touch. drop air bags or crank a couple more turns. little trick is to roll down legs and crank a couple turns till u hear air. then back just the truck up and set the brakes. dont let it roll forward before. then try and pull fifth wheel.
  6. BukowskiFlowers
    60
    23
    Jan 24, 2017
    Manual release
  7. JonJon78
    JonJon78 Road Train Member
    7,241
    43,044
    Jul 1, 2018
    Is your 5th wheel release handle not holding and when you try and detach the jaws close?
  8. Vic Firth
    1,843
    4,303
    Jan 19, 2016
    Indiana
    It might be a mechanical failure can you see if the jaws have released? You might need someone to pull and hold the handle while you pull out.
  9. sirjeff
    sirjeff Medium Load Member
    Might be one of those goofy 5th wheels where the handle has to be pulled up or down then out? Or is it the other way around.... pulled then locked in a notch up or down? I cant remember. I know I struggled with one once, and it won. Cus I went flying and landed on my ###.
  10. BukowskiFlowers
    60
    23
    Jan 24, 2017
    I'm in Georgia but yeah it's in the 40s.
    I did what you said it won't come loose. Earlier I had the same problem and a guy had me hold a button on the dash with a truck and lock on it. It got me loose. I can't remember the exact series of things he told.me to do though.
  11. truckdriver31
    6,998
    8,363
    Sep 18, 2013
    omg do i hate those.
    mitrucker, VIDEODROME and KB3MMX Thank this.
