Tractor wont or cant idle???
Discussion in 'Ask An Owner Operator' started by Trucker327, Jul 19, 2019.
  1. Trucker327
    Trucker327 Light Load Member
    176
    20
    Dec 24, 2017
    Alright so first things first...i know how to idle...BUT I have a 14 freightliner cascadia...the only thing is...i dont have that box (cant remember the name..long day) in my sleeper that you usually press when idling...every tractor Ive drove has had one...but this one does not...so does anyone know how to idle?? From what i know...you have to have that to idle. I mean is there even a way to idle?? Can it even idle?? Its wayyy to hot to not have some air flow going on!!
  3. DTP
    DTP Road Train Member
    1,281
    2,709
    Dec 9, 2014
    Drop the landing gear on the trailer, release the tractor brakes, and go to sleep. Releasing the parking brake should bypass all that anti-idle nonsense
    Cattleman84 and FlaSwampRat Thank this.
  4. 86scotty
    86scotty Road Train Member
    4,728
    12,990
    Aug 27, 2017
    Appalachia
    Not necessarily. My old company had late model Cascadias and had them setup where absolutely nothing we did would make them idle. They were day cabs so we didn't fight it but we tried everything, all the brake and cruise control tricks, everything. You could even put a tire thumper between the driver's seat and the pedal to idle them up (with brakes off) and they would cut off after 3 minutes.
    Modern trucks are highly computerized. If they program them to shut down you won't beat it.
    If you drive for a company that won't let you idle or put an APU on the truck for climate control they that company is truly evil and doesn't care about your well being.
    Trucker327, you've posted this in the owner operator forum, so is this your truck? If so, take it to Freightliner and have it the shutdown turned off in the programming.
    bzinger, Trucker327, DTP and 1 other person Thank this.
  5. DUNE-T
    DUNE-T Road Train Member
    7,058
    17,201
    May 10, 2015
    Detroit, MI
    Do you own this truck? If so go to a dealer and have them remove idling restrictions
    DTP, mhyn and FlaSwampRat Thank this.
  6. tnevin225
    tnevin225 Road Train Member
    1,166
    1,601
    Jan 1, 2014
    I wonder if he finally passed out from the heat?:eek:
    JoeyJunk, bzinger, rachi and 7 others Thank this.
  7. Old-school trucker
    Old-school trucker Light Load Member
    189
    334
    Sep 12, 2016
    Are you talking about the optimized idle?
    Dave_in_AZ and mhyn Thank this.
  8. JJB1960
    JJB1960 Bobtail Member
    While parked hit the cruise control to on and go up or down with your rpm withe the resume button
  9. Dave_in_AZ
    428,146
    Sounds like he's had opti idle, but doesn't now.
  10. Trucker327
    176
    20
    Dec 24, 2017
    So even tho..i dont have that box in the sleeper...i still have a way to idle? Bcause that box is what controls the temp..is that what your saying? Bcause i was told different...
  11. Trucker327
    176
    20
    Dec 24, 2017
    Yes
