Trading hopper bottom for an end dump
Discussion in 'Tanker, Bulk and Dump Trucking Forum' started by W Bench Farms, Oct 5, 2023.
  1. W Bench Farms
    W Bench Farms Light Load Member
    211
    351
    Oct 16, 2017
    I currently have a 40' steel hopper bottom I mainly use for the farm. Haul a few local loads every now and then. Semi is usually hooked to a flatbed. Last year I think I hauled a total of 6 loads with the hopper. I'm thinking of selling the hopper and getting an end dump. I need a trailer to mainly haul my grain to the elevator. But, I thought that an end dump may be a little more versatile, and I may get some more use out of it. Also have an opportunity to fill in hauling fertilizer locally. If I do go this way, I'm not sure on going full frame or frameless, and what length would be my best option. Would be pulled with an FLD 120 with a 220" WB. Want to have enough bridge to gross 80k. My current flatbed setup is a 48' spread, and light weight is 29500. With the hopper I'm 33600 empty, so can put about 800 bu corn on and be legal.
    NightWind Thanks this.
  3. SomeCanadian
    SomeCanadian Light Load Member
    166
    481
    Nov 11, 2021
    I haven’t pulled a frameless, but I would suggest full frame. Slightly more rugged, and for unloading in the field I would think it should be more stable. The 30ish footer I pulled for a bit was too easy to overload the trailer tandems. I would suggest a triaxle
  4. SL3406
    SL3406 Medium Load Member
    551
    1,502
    Jan 10, 2011
    Oklahoma
    If you need to bridge 80k you will need a 39' trailer. I would go with a frameless because a frame type that long will be too heavy.
  5. abyliks
    abyliks Road Train Member
    4,121
    9,707
    May 2, 2010
    ludlow MA
    Frame trailers suck, 39-40’ frameless is probably what you will want
    motocross25, Al. Roper and Last Call Thank this.
  6. W Bench Farms
    211
    351
    Oct 16, 2017
    Thinking of going with a 39-40' frameless. Trying to go look at a few soon. Just wondering if tandem or spread would be the way to go. I know a spread drags tires more, but can't be worse than my flatbed. How do you guys pick up freight? I'm in northeastern Ohio, and it seems like 40-50% of the trailers on the road around me are end dumps. R&J, D&V, Page, etc all run around here. I have my own authority, and don't want to lease on. What I'd really like to do is just pick up a load or 2 a week here and there. I stay busy on the farm, but when we slow down I get in the truck more.
    NightWind, Sons Hero and W923 Thank this.
  7. abyliks
    4,121
    9,707
    May 2, 2010
    ludlow MA
    heard good things about page, was actually planning on going there while I was building my truck, funny how things change, start calling them and see if any of them have brokerages too
    I’d do a spread axle trailstar if I was going with a big trailer, actually had a 30’ spec’d out before I bought my MTM but wasn’t doing demo work with aluminum
  8. Trashtrucker1707
    Trashtrucker1707 Road Train Member
    1,771
    5,164
    Dec 30, 2017
    US Bulk has a brokerage, I’m sure you could haul for them as you please. Also try Bulk Loads dot com on the old interweb, lots of loads posted there.
    Sons Hero, W923 and motocross25 Thank this.
  9. W923
    W923 Road Train Member
    1,419
    4,389
    Feb 28, 2022
    I would look for 26-30 foot full frame all aluminum trailers and get a good full liner. The frameless is fine for hauling grain but I don’t care for them dumping lime in fields and most construction jobs around here won’t use them. And hauling grain is marginally better than flipping burgers or at least that’s been my experience in west central Illinois.
    Sons Hero Thanks this.
  10. W Bench Farms
    211
    351
    Oct 16, 2017
    My truck is 220" wheelbase. What can you gross with the shorter trailers? Does less than 80k cut your rate much?
    W923 Thanks this.
  11. ducnut
    ducnut Road Train Member
    2,683
    8,131
    Dec 31, 2010
    SPI
    All the ag businesses and corporate farms around me (central IL) run what appears to be 39’-40’ length frameless, tandem, and usually MAC brand. I’ve never seen a shorty being used for what you’re wanting to do.
    The OTR end dumps I see, such as Oakley, are usually spread axle. I’d definitely spec a dump valve on the rear axle, if you go that route.
