Trailer air line support springs
Discussion in 'Ask An Owner Operator' started by 86scotty, Jun 29, 2019.
  1. 86scotty
    86scotty Road Train Member
    4,925
    13,650
    Aug 27, 2017
    Appalachia
    Last night I noticed one of my springs that hold my airlines up on my rear tandem broke and the other one doesn't look good either. I'm nowhere near a trailer shop. Are these common at a truck dealer?
    Also, would I get hassled by DOT if I bungee them for now? I was thinking get under there with bungees and redo them bending the S hooks so they can't come loose until I find the proper springs.
    JoeyJunk Thanks this.
  3. 062
    062 Road Train Member
    6,439
    34,437
    Oct 20, 2013
    Dealers will have a few springs in stock. Measure what you have now.
    You may have to come up with a different way to mount it to the trailer if you have the ones with the tab mount.
    86scotty Thanks this.
  4. don't bungee.. use the heavy duty tarp flatbed straps..
    you'll be fine just don't go a long time but as long as you got them hung up and utilize some of the holes in the trailer or places where you can hook them you should be fine I've done it before when I've had a spring break and not dragging busting airline
  5. Michael 247
    Michael 247 Heavy Load Member
    896
    4,718
    Nov 20, 2017
    Dublin Va
    Any Truck Shop should have them..Might find them at a Truck Stop...Bungees will be ok for now..if it drags on the pavement it takes 3 seconds to rub a hole in it and lose all air pressure..Good thing you found it Before leaving..
  6. 86scotty
    4,925
    13,650
    Aug 27, 2017
    Appalachia
    I'm old school I guess. When I say bungee I mean the strong black rubber bungees with a steel S hook I can bend. I think that's what you mean too.
  7. 86scotty
    4,925
    13,650
    Aug 27, 2017
    Appalachia
    Actually I didn't. I found it last night doing a post trip after a near 700 mile day. I got pretty lucky. Truck won't move until Monday morning but I don't live anywhere near a truck shop.
  8. 062
    6,439
    34,437
    Oct 20, 2013
    If you’re at home check the local hardware store.
  9. Kshaw0960
    Kshaw0960 Road Train Member
    1,581
    5,025
    Jun 17, 2018
    Back when I was a company driver drop and hooking 4-15 trailers a day... I just use zip ties.
    1. Inform company of issue
    2. Use 2-3 zip ties (beefy ones)
    3. Ride on
    Reasons: zip ties will snap without damaging hoses when/if tandems get slid to the rear.
  10. yes..what if you don't mention the flatbed tarp straps a lot of people may try a bungee bungee cord if you know what I mean. they're just not strong enough many times one good bounce or two and next thing you know they snap in the plastic little hooks
