trailer air supply problem
Discussion in 'Peterbilt Forum' started by comebackkid79, Aug 4, 2016.
  1. 062
    062 Road Train Member
    6,354
    34,045
    Oct 20, 2013
    Do you have air into and out of the tpv?
    If so do you have check valves going to air lines?
    BoxCarKidd Thanks this.
  3. AModelCat
    165,592
    Been a while but IIRC trailer air is supplied blended air from both tractor primary and secondary reservoirs via a 2 way check valve. Maybe its stuck closed?
    comebackkid79 and Old school 362 Thank this.
  4. Old school 362
    Old school 362 Medium Load Member
    392
    249
    Mar 6, 2016
    Pensacola Fl
    Goggle Peterbilt air brake diagram. Show the basics of the system. Need to find the air line from dry tank, too red dash valve. Check for obstruction.
    comebackkid79 and BoxCarKidd Thank this.
  5. BoxCarKidd
    BoxCarKidd Road Train Member
    4,567
    6,655
    Aug 26, 2014
    That check valve thing from NM rings a bell. 78 IHC had three of them next to each other up under the dash. Lost a week of my life to find the that and correct what everyone else crossed up changing valves.
  6. comebackkid79
    comebackkid79 Bobtail Member
    6
    I'll check that out thanks!
  7. resistol
    resistol Bobtail Member
    4
  8. resistol
    4
    I'm having problems that #1 tank is supplied with air but #2 tank stays at 0
  9. BoxCarKidd
    4,567
    6,655
    Aug 26, 2014
    You should start a new post with your problem and what your truck is posted.
  10. LargeMarge84
    LargeMarge84 Bobtail Member
    I know it’s been 7 years but I’m having the exact same problem. What did it end up being wrong?
  11. BoxCarKidd
    4,567
    6,655
    Aug 26, 2014
    Suggest you start with BigPerms list of things to check.
