Trailer axles won’t slide
Discussion in 'Ask An Owner Operator' started by yeah, Jul 20, 2023.
  1. yeah
    yeah Bobtail Member
    15
    Jul 28, 2022
    Hi, my trailer axles won’t slide when I’m loaded. They only slide when I’m empty. What’s the issue? Thanks
  3. Long FLD
    Long FLD Road Train Member
    13,203
    55,502
    Mar 4, 2015
    Spray inner slide lube on the slider next time you’re empty and slide them back and forth a few times.
  4. Lockport
    Lockport Light Load Member
    201
    131
    Mar 26, 2011
    Lockport, MB, CAN
    I carry around 4x4 sections of hardwood about the length of a pair of tandems to block the wheels when I'm having difficulty. It's not unusual to have that happen when you're loaded.
  5. snowwy
    snowwy Road Train Member
    20,626
    13,350
    Jul 6, 2009
    If you have to use 4 x 4. The brakes aren't adjusted. Nor are they working.
    If the brakes are adjusted. That trailer isn't moving. And you won't need to pack wood.
    Pack tools instead. To adjust the brakes.
    A good brake adjustment on all 5 or more axles is very important to stopping loaded semis.
  6. Keepforgettingmypassword
    Keepforgettingmypassword Heavy Load Member
    738
    938
    Jan 11, 2022
    I had used a land star trailer that was a hot mess. Loaded or not the trailer would only slide if I was on a steep hill. I tried the greese, the rolling nail the trailer brakes. The and the blocks. This thing had to be on a steep incline/ decline, depending on which way I had to slide them.
  7. xsetra
    xsetra Road Train Member
    5,204
    7,159
    Aug 21, 2011
    I had a trailer I had to do this with sometimes. The brake spring was weak enough to let the axle roll under power, yet strong enough to hold it while parked. I would use the johnny brake or a 4x4 to hold and slide the trailer axle.
    Snailexpress Thanks this.
  8. abyliks
    abyliks Road Train Member
    4,227
    10,071
    May 2, 2010
    ludlow MA
    If you have to put a wrench on an auto slack it’s time to throw them away, unless of course you have something older then 94 with manuals
    ducnut and rollin coal Thank this.
  9. snowwy
    20,626
    13,350
    Jul 6, 2009
    Yep. But in the mean time. A wrench will keep you from being oos.
    And rear ending someone.
