Trailer brake issue
Discussion in 'Questions From New Drivers' started by RedRover, Aug 26, 2020.
  1. RedRover
    RedRover Road Train Member
    1,794
    2,617
    Sep 10, 2016
    Corsicana, TX
    Random oddity taking place I don't know how to troubleshoot... Picked up a new trailer and pretripped it. Brand new trailer. About 100 miles loaded down the road my brakes were smoking. Flat land, no traffic. 100 highway miles. Stopped and let them cool down with the trailer brake released.
    Made my delivery and headed back to the yard. Same thing happened 3 more times. Reported a brake issue to the shop. Brakes on a new trailer were toast. New trailer maybe some issues. No big deal. Grab another trailer. 20 miles away, same issue on another trailer, this one with 50k miles on it.
    What would cause my brakes to engage only on my trailer and only just enough to cause the slight squealing noise that air brakes make when a big rig is releasing or slightly engaging their brakes to slow down... Constantly. Even at highway speeds? Peterbilt says it may be the trailer protection valve or something. Guess I'll find out tomorrow.
  3. AModelCat
    165,355
    Left the spike on slightly?
  4. WesternPlains
    6,372
    57,552
    Sep 1, 2017
    Rapid City, SD
    They always suspect the tractor protection valve.
    Squealing noise. Water in the air system? Try draining?
    In order for your trailer spring brakes (parking brakes) to engage properly. You need good air to them. Often times, they won't respond properly if you do not have the air fully charged (not just good air). I mean fully charged. Then dump the air. They should engage properly.
    I imagine the releasing of them could have something to do with air supply? Water in system?
  5. daf105paccar
    6,564
    7,294
    Apr 15, 2012
    Drums or disks?
  6. Allow Me.
    10,788
    12,674
    May 28, 2009
    Rancho Mirage, Ca.
    I have picked up new trailers and the brakes smoke because brand new brake shoes against brand new drums ....rubbing a little
  7. Espressolane
    18,851
    118,448
    If you had two different trailers do the same thing, it would be a good guess that it may be in the tractor.
    There are a few things that could be going on.
    Treadle valve. It has two valves, if one is leaking, it could be feeding the trailer.
    If you have a trailer brake lever in the tractor, it could be leaking.
    The tractor protection valves could be failing.
    Additional components that could also cause problems(rare) the front and rear proportioning valves and the spring brake valve.
    randomname Thanks this.
