Trailer brake lights stuck on.
Discussion in 'Freightliner Forum' started by Diesel13230, Nov 30, 2023.
  1. Diesel13230
    Diesel13230 Bobtail Member
    15
    15
    Nov 30, 2023
    So I followed glad hand lines and they go to that valve. There is no valve at the port but a small 1/4 orange line leading off. I followed it and it went up in the dash to a bank of sensors. I unplugged the sensor going to the orange line and the lights stayed on. Had 12V going to sensor. Tested continuity at the sensor and it was O.L and when I applied air there was no resistance. Sensor is good.
    What else can I check?
    I need a wiring diagram and maybe my freightliner dealer would be kind and give me one but would any of you have one you would be willing to send me?
    Rideandrepair Thanks this.
  3. Big Road Skateboard
    7,540
    43,245
    May 2, 2021
    Swap the trailer brake light relay with another. The relays often stick
    Rideandrepair, Diesel13230 and JB7 Thank this.
  4. Diesel13230
    15
    15
    Nov 30, 2023
    So I followed the wiring for the trailer all the way up to almost behind the cab and when I disconnected it there the lights went off and I tested power there and found that I have 12 v going down the line to the trailer brake light wire. So I know that the truck (Or stray wire) in the front of the truck sending power back.
    IH Truck Guy and Rideandrepair Thank this.
  5. Diesel13230
    15
    15
    Nov 30, 2023
    Swapped them and still the same issue.
  6. Big Road Skateboard
    7,540
    43,245
    May 2, 2021
    Do they stay on if you just pull the relay, or do they go out?
    Rideandrepair and Diesel13230 Thank this.
  7. Diesel13230
    15
    15
    Nov 30, 2023
    they go out
  8. Diesel13230
    15
    15
    Nov 30, 2023
    They are always on when key is on and I can feel the relay clicking when removing/installing it.
  9. Big Road Skateboard
    7,540
    43,245
    May 2, 2021
    Then it's getting a signal from somewhere. Meaning everything from the relay to the trailer is most likely good. No lights on the truck, key on?
    Diesel13230 and Rideandrepair Thank this.
  10. Diesel13230
    15
    15
    Nov 30, 2023
    correct, truck brake lights work fine.
  11. Diesel13230
    15
    15
    Nov 30, 2023
    Another thing is when I pull the relay the ABS valves on the trailer do a quick check and click a few times just on the trailer.
