trailer brakes wont set
Discussion in 'Peterbilt Forum' started by bobbycalfee, Jul 25, 2014.
  1. bobbycalfee
    bobbycalfee Bobtail Member
    I have a 387 and when I pull the dash valve the truck breaks will set but the trailer breaks wont, and it does it with all trailers. they will set if I get out and break the airlines. I cant figure this out.
  3. 201
    201 Road Train Member
    12,834
    26,420
    Apr 16, 2014
    high plains colorado
    Hi bobby, could be moisture in the system, try draining the air tank on the trailer, otherwise, there's a distribution valve above the trailer axles, unit with 4 air lines, one going to each wheel, could be stuck. If anti-lock is involved, I can't help ya.
  4. freightlinerman
    freightlinerman Road Train Member
    1,287
    536
    Mar 4, 2011
    Florida
    HE says this happens with all trailers. It would seem to be a tractor specific problem. I'd start with the red valve, that's where air comes in and air goes out. There should be a vent where the air exhausts, all the plumbing is on your firewall. Good luck.
  5. 201
    12,834
    26,420
    Apr 16, 2014
    Oh yeah, duh, I see that now.You are right, something is preventing the air to be released. My 359 had a valve under the cab that the emergency line came from, maybe that's bad. I never had a red button valve go bad, but it's possible. Plugged line? Once, I helped a guy with brake problems, we took the line off a brake chamber, he pushed on the brake, and all this oily water jiz came shooting out.
  6. GrapeApe
    GrapeApe Road Train Member
    2,215
    2,212
    Jan 7, 2013
    Sounds like you have a QR valve not working, or a probem in the dash valve itself. I had one doing this once and found that the QR valve on the back of the cab (Sterling) was replaced with a check valve. The QR valves were known to leak on those and someone must have thought it was a check valve. It was not letting the air out of the trailer.
