Trailer brakes
Discussion in 'Ask An Owner Operator' started by pavrom, Jul 1, 2022.
  1. pavrom
    pavrom Road Train Member
    3,223
    7,452
    Apr 29, 2012
    NE illinois
    I have strange issue noted by mechanic during last pm service . I replaced my trailer brakes maybe 2-3 months ago and now the upper brake shoe pad is separating because of loosen rivets( all 4 corners ) . I am the only one using this trailer since new and never had this issue before , same mechanic replaced brakes probably 7-8 times on different types of equipment for me ( car hauler trailer , flat bed trailer , regular trucks ). He called the supplier and sales said this is the first time they hear the issue and if we want credit/exchange - store has to ship those shoes to the manufacturer for evaluation , they said probably overheated brakes - i never overheated them .
    Any ideas?!
    jamespmack Thanks this.
  3. wichris
    wichris Road Train Member
    4,517
    9,298
    Jan 17, 2011
    Bad cores, pi$$ poor rivet job. I've had some do that and if you take the pad off the core is rough/pitted.
    Bean Jr., Siinman, jamespmack and 3 others Thank this.
  4. Magoo1968
    Magoo1968 Road Train Member
    2,062
    5,493
    Mar 18, 2021
    St Malo mb
    A buddy got warned in northern Wisconsin about same issue . The DOT inspector told him he’s been a lot of that lately.
    AModelCat and jamespmack Thank this.
  5. jamespmack
    Thats my thoughts. You could remove and use a brake lining bolt kit to repair this. But it sounds like it is still less than quality reman brake kits.
  6. wichris
    4,517
    9,298
    Jan 17, 2011
    Big difference in price between re-lined and new. Nothing wrong with re-lined if the cores aren't pitted/corroded.
    Bean Jr. and jamespmack Thank this.
  7. jamespmack
    Yes and if they check for worn anchor points. In my world they rust jacket before I wear them to 50%. I have tried everything except stainless steel. I might have to.
    Magoo1968 Thanks this.
  8. wichris
    4,517
    9,298
    Jan 17, 2011
    We run in the north so just us re-lined. With the discs there is no problem with it, just for everything else underneath the trailer
  9. jamespmack
    I run Ohio, Indiana, and Michigan. I can't wear them out. Even the meritor coated linings. I was told I dont use my brakes hard enough.
    Bean Jr. and Magoo1968 Thank this.
