Trailer Clearance Lights...ARGH!!!
Discussion in 'Trucks [ Eighteen Wheelers ]' started by Gears, Apr 12, 2010.
  1. Gears
    Gears Trucker Forum STAFF - Gone, But Not Forgotten.
    4,511
    3,185
    Aug 20, 2009
    I've got a few side clearance lights on my Great Dane trailer that need bulbs replaced. Thought I'd take a phillips screwdriver and remove the light/lense pop in a new bulb and reinstall. These are just the 2x6 amber lights, held on with two screws.
    I must be doing something wrong. The darn screws wont turn at all. Am I missing something here? Why in the heck won't they turn? I've replaced lights on other trailers with no issue. I'm close to stripping the heads off some of these.:biggrin_25510:
    Anyone deal with such a thing before? Suggestions? Advice?
  3. Superhauler
    Superhauler TEACHER OF MEN
    12,209
    100,735
    Jan 30, 2010
    keep stroking.
    you will probably twist them off. they are probably self taping if they are in alum and if you can without melting anything heat up the alum with a little mini torch to expand the hole alum will expand faster than steel. it wont take much.
    Gears Thanks this.
  4. Gears
    4,511
    3,185
    Aug 20, 2009
    You're right, they're mounted on an aluminum rail. I suppose I could put some heat on from the backside and see if that helps.
  5. Roadhound
    Roadhound Light Load Member
    283
    113
    Jan 31, 2007
    Tennessee
    The steel screws oxidize with the aluminum side rail, and it works just like lock-tite. I recently replaced all the lights on my Great Dane reefer with LED's and had to re-drill holes for at least half of the lights on the bottom. I feel your pain on this one. But it's not just with a Dane, all of them do it.
    Gears and The Challenger Thank this.
  6. Superhauler
    12,209
    100,735
    Jan 30, 2010
    keep stroking.
    just be careful not to melt wires i ment to also say to get a junk screwdriver put on the screw and tap it with a little hammer to break the oxidied alum that may work also
    Gears Thanks this.
  7. Gears
    4,511
    3,185
    Aug 20, 2009
    I had a feeling it might be something like this as well. Darn things won't budge. I'd love to replace them with LED's, but with all the lights on this unit...it'd cost a small fortune. Thought about replacing with LED bulbs and discovered they're about the same price as a whole new light. :biggrin_25523:
    Thanks for your post!
  8. Heavyd
    Heavyd Road Train Member
    7,827
    6,276
    Feb 4, 2009
    If you don't want to spend all day just fixing a couple of lights, the quickest way when the screws are seized in is to just smash them off with a hammer and prybar. Drill new holes and redo your wiring. DO NOT USE SCOTCH-LOCKS!!! These are not weather tight and will corrode the wire in no time!
    Gears Thanks this.
  9. Gears
    4,511
    3,185
    Aug 20, 2009
    Don't worry about the Scotch-Locks... I don't even know what the heck those are:biggrin_2559:
  10. Roadhound
    283
    113
    Jan 31, 2007
    Tennessee
    The lights I replaced mine with are United Pacific brand and were only about $7 a piece. And you might get a little discount if you buy several at once.
  11. RW.
    RW. Heavy Load Member
    715
    995
    Jan 18, 2009
    west central IL
    When you put them back together, use stainless screws and put anti-seize on them, that will help keep them from being stuck next time.
