Trailer disconnect switch.
Discussion in 'Experienced Truckers' Advice' started by LoneRanger, Apr 30, 2019.
  1. LoneRanger
    LoneRanger Road Train Member
    3,695
    9,605
    Jun 3, 2018
    what in the world does it do?
    I tried it when parked and hoses disengaged just to see what it does and all it does is let air out of the red line.
    I’m scratching my head here.
    Any help appreciated.
    Also it’s a Fontaine 5th with air slide.
    D.Tibbitt Thanks this.
  3. starmac
    starmac Road Train Member
    6,639
    12,528
    Apr 11, 2019
    Fairbanks Ak
    Sounds like it should unlatch your fifth wheel.
    try it bobtail with it on and see if you have real brakes. I have never seen a switch for this, but I put valves o mine so I can charge the trailer brakes while bobtailing, so as to have real brakes.
  4. LoneRanger
    3,695
    9,605
    Jun 3, 2018
    I’m lost, what does charging trailer brakes while bob tailing mean?
    And what do you mean real brakes?
    Guess I’m in class now.
    roshea, booley and 86scotty Thank this.
  5. Casper88
    Casper88 Bobtail Member
    28
    159
    Feb 21, 2019
    Chicago
    If it's the one I'm thinking off it shoots air to the trailer brakes like a trolley valve, but only when your parked. It's so you can check for leaks and your lights. Also if your hooking a pre 1979 (might be wrong with the year) trailer without spring brakes.
    x1Heavy, gentleroger and D.Tibbitt Thank this.
  6. starmac
    6,639
    12,528
    Apr 11, 2019
    Fairbanks Ak
    Many trucks have less braking power to the tractor, a lot less, in other words when you are bobtailing you really have to mash the brake pedal. If you charge the trailer valve (push it in) it will restore your brakes to normal,but if you do not have the lines blocked off, the air just runs through and dumps.
    I put valves on mine.
    What year model is this truck that has that switch?
    Biomagnum and 86scotty Thank this.
  7. LoneRanger
    3,695
    9,605
    Jun 3, 2018
    2013 Cascadia.
    I’ve bob tailed with the truck and brakes are the same when connected to trailer.
    Maybe this is the reason.
  8. Cattleman84
    Cattleman84 Road Train Member
    10,007
    71,371
    Nov 1, 2017
    The Sticks, Idaho
    Picture??? Not that will help much but just curious.
  9. LoneRanger
    3,695
    9,605
    Jun 3, 2018
    I have to get it tomorrow, but I’m guessing my rig is equipped with a 5th wheel that has the capability of releasing the jaws from inside the Cab.
    But if that’s the case then why is air released out of the red line?
    Cattleman84 Thanks this.
  10. ZVar
    ZVar Road Train Member
    10,911
    23,833
    Sep 10, 2010
    Flint, MI
    It's not. If it was to release the jaws it would tun to a second air piston on the fifth wheel next the the piston that releases the slide.
  11. LoneRanger
    3,695
    9,605
    Jun 3, 2018
    It’s located next to the slide switch so im guessing it’s for the jaws, but why put air into the red line when turned on?
