Trailer Door Closing Problem
Discussion in 'Experienced Truckers' Advice' started by BobTheDriver, Jun 27, 2013.
  1. Cranky Yankee
    Cranky Yankee Cranky old ######
    15,317
    210
    Jan 31, 2012
    Green Bay Wi
    is the "tool" also known as "the massager"
    gentran Thanks this.
  3. Grouch
    Grouch Road Train Member
    2,126
    4,409
    Feb 3, 2009
    Between here and eternity
    I ain't named it.
  4. Cranky Yankee
    15,317
    210
    Jan 31, 2012
    Green Bay Wi
    if the little hammer doesn't work
    the sledge usually does
    I save the heavy duty hammer for the office staff
  5. opnbar
    opnbar Bobtail Member
    4
    Apr 19, 2017
    helps w shipping container or truck trailer doors that are stuck
  6. HiLoSapien
    HiLoSapien Light Load Member
    167
    324
    Mar 1, 2017
    Picked up a dry van today that had to be persuaded to latch. If a driver doesn't carry a little sledge.... Well, I just don't even know what to say to that.
  7. Toomanybikes
    Toomanybikes Road Train Member
    2,490
    3,496
    Apr 8, 2009
    Most trailers have driver's side door close first and then passengers. The doors overlap and interlock. Is this your problem?
    Bent lock rod? Loose latch? I mean everything mechanical is visible on the trailer door. A simple visual inspection of the components will almost always clue you in to the problem.
  8. Accidental Trucker
    Accidental Trucker Road Train Member
    3,439
    7,815
    Jun 4, 2015
    In some cases you have to physically lift the door to align things. One one of our trailers it helps if you close both doors at the same time, one pushes against the other in the right spot for things to align.
    Since we load off road, on occasion we just have the driver pull forward slowly while we close the door as the trailer is moving. Enough wiggle back and forth to drop the latch
    easily.
    Lepton1 Thanks this.
