Trailer floor rating
Discussion in 'Ask An Owner Operator' started by simon999, Mar 20, 2014.
  1. simon999
    simon999 Light Load Member
    240
    95
    Feb 6, 2014
    I am looking to get wabash dry van plate trailer. They have floor rating from 20,000lbs to 35,000lbs. I am hauling loads from 35k to 45k. Which floor rating would best to choose?
  3. High Desert Dweller
    High Desert Dweller Medium Load Member
    431
    389
    Jan 29, 2009
    Is that the Dynamic Floor Rating? I don't believe it refers to the gross weight you will be hauling. It refers to the tensile strength of the floor i.e. the amount of weight needed to cause the floor to fail at a concentrated point. IMO, a 20k rating sounds fine (a much lighter trailer) but you should double-check with Wabash. I'm not an expert.
  4. Sly Fox
    Sly Fox Road Train Member
    1,016
    695
    Oct 29, 2009
    From what I gather, the weight rating is the most the floor can handle in '10 feet' of trailer length. This would also include fork lifts loading, etc.
    Same reason a flatbed can haul a steel coil, but a regular dry-van can't. Concentrated weight. Most weight you're going to haul is palletized or floor loaded, so the weight is dispersed through the length of the trailer.
    Only thing I've read about needing a higher rating is for the super-heavy paper rolls (because of the large forklift carrying them into the trailer). Generally, a standard fork lift bringing 2k-3k lb pallets onto your trailer wouldn't ever exceed your weight rating.
  5. Dale thompson
    5,452
    47,175
    Nov 20, 2013
    commerce twp,mi
    go with at least 26,000 floor rating if you want a long service life.
  6. freightrunner
    freightrunner Heavy Load Member
    722
    182
    Mar 25, 2012
    Georgia
    Most dry vans have floor ratings on 20k. But if buying used I would look for a higher floor rating only because of age. But if you're buying new You should be good.
  7. simon999
    240
    95
    Feb 6, 2014
    I called today wabash standart trailers are 20k rating which gross of trailer gvwr would be 70000lbs. I asked what if I haul paper rolls? They said then to choose 24k floor. Right now I drive stoughton it has 22k rating
  8. Richter
    Richter Road Train Member
    4,090
    1,700
    Feb 13, 2012
    Philadelphia Pa
    Depends on what you haul. Think about this. If you hual stuff that is heavy loaded by a big forklift, you want the higher ratings. A 5000 pound roll of paper loaded by a 10k forklift is a lot of weight. A 3k forklift lifting a 2000 pound pallet of food isn't so bad. If it were me, i'd pay extra for the better floor so i have more flexibility with future loads.
  9. rollin coal
    rollin coal Road Train Member
    13,617
    27,992
    Mar 29, 2008
    TN
    If you've ever hauled powdered iron it's usually 45,800 lbs on 9 skids. 4 skids in the nose and 5 scotched over the tandems. Not counting forklift weight. Or slinky coils loaded from front to back right down the middle of the trailer are concentrated. I would go a little higher than standard 20-22k. If you haul loads like that all the time you need it. If only occasional you don't need to stress your equipment possibly having catastrophic failure.
  10. WildRose
    WildRose Light Load Member
    59
    17
    Nov 15, 2007
    Hartford, CT
    Flatbed has two huge beems under it. Dry Van is an engineered structure and has wastbands act as the Beems though the whole structure walls and roof all combine to carry the load. Why they fold so easily. I think if it like a the box a single sleve of cookies of crackers come in. Or a crane boom. Fine when everything is loaded right. disastrous once they start to fail.
  11. WildRose
    59
    17
    Nov 15, 2007
    Hartford, CT
    Flatbed has two huge beems under it. Dry Van is an engineered structure and has wastbands act as the Beems though the whole structure walls and roof all combine to carry the load. Why they fold so easily. I think if it like a the box a single sleve of cookies of crackers come in. Or a crane boom. Fine when everything is loaded right. Desterous
