Trailer hub gasket
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by GliderKitTrucker, Jun 26, 2020.
  1. GliderKitTrucker
    GliderKitTrucker Light Load Member
    50
    36
    Dec 28, 2019
    If you’re replacing trailer hub baskets, should you use a sealant between the gasket and the hub and hub cap to prevent hub oil from leaking?
  3. bad-luck
    bad-luck Road Train Member
    3,438
    6,331
    Nov 16, 2013
    Baltimore, Maryland
    I have seen people do it, but you don't have to. Just like the axle hubs on a tractor. Some people think sealant is better. But its really a preference
  4. Goodysnap
    Goodysnap Road Train Member
    3,773
    9,199
    Jul 12, 2017
    No sealant. Paper gaskets are intended to be installed clean and dry.
    PE_T, Rideandrepair, pushbroom and 3 others Thank this.
  5. AModelCat
    164,678
    The whole purpose of a gasket is to seal the 2 surfaces. Sealant not needed.
    PE_T and Rideandrepair Thank this.
  6. GliderKitTrucker
    50
    36
    Dec 28, 2019
    I was just curious... I replaced mine a while back on my trailer and I used the rubber textured gaskets...never been a fan of the paper ones... but I’ve noticed that a couple of my hubs have a little dampness, it’s not slinging anything on the wheels but I can’t stand any kind of leak
  7. AModelCat
    164,678
    Might have to snug the bolts down a bit more if its sweating a bit. Sometimes those little bolts loosen up.
    PE_T Thanks this.
  8. GliderKitTrucker
    50
    36
    Dec 28, 2019
    I’ll check that cause i torqued them to like 7 pounds I think and checked them after a hundred miles when I done it and I ain’t gonna lie I ain’t checked them since
  9. Goodysnap
    3,773
    9,199
    Jul 12, 2017
    7 ftlbs?
    Your a tad light my friend. Every hubcap I have ever seen is 5/16" fasteners. Should be more like 20.
