Trailer "jumps/hops/skids" When Braking Empty/Light Load
Discussion in 'Ask An Owner Operator' started by Ikamob01, Apr 1, 2022.
  1. Ikamob01
    Ikamob01 Medium Load Member
    314
    195
    Dec 4, 2021
  3. Keepforgettingmypassword
    Keepforgettingmypassword Heavy Load Member
    738
    938
    Jan 11, 2022
    Does the abs light on the dash ight up?
    I'm just guessing here. But it sounds like the tractor is stopping harder or faster than the trailer. The sudden stop of the tractor is causing the bounce.
    I would check out the brake adjustment First.
    Rideandrepair Thanks this.
  4. mnmover
    mnmover Road Train Member
    1,237
    1,104
    Apr 5, 2009
    Lichfield MN
    Check the crack air pressure on the valves. And / or your tractor protection valve. Sounds like trailer is getting too much air when you apply the brakes. Brake adjustment could be also a problem, but with self adjusting brakes they should all be the same.
  5. Midwest Trucker
    5,914
    21,390
    Aug 31, 2018
    I once had this problem. The solution after spending a ton of money trying to figure it out was to sell the trailer. ;)
  6. Rideandrepair
    17,576
    56,940
    Aug 8, 2015
    Too much air in the air bags will cause it. Check height valve. Otherwise it’s the greatest mystery of all time. I had one that did it. Replaced ECU/Valve unit. That fixed it for a short while. After that, a hard stab on the pedal would Somehow reset it, and make them stop locking up. It’s a common and dangerous thing, especially when it’s raining or snowing.
