Trailer Securement Options
Discussion in 'Flatbed Trucking Forum' started by CharlieK, Oct 16, 2015.
  1. CharlieK
    CharlieK Medium Load Member
    374
    4,454
    May 13, 2015
    Minnesota
    I have an older Fontaine flatbed that has stake pockets, 24" on center... with one spool in between. I'm working on a brand new Transcraft, that has stake pockets, 24" on center... with two spools in between each pocket. Wish mine Fontaine was like that...
    I'm considering building a couple of stepdecks... curious what you folks like...
  3. Hurst
    Hurst Registered Member
    6,618
    12,266
    Aug 24, 2011
    Tampa, Fl
    Ratchet spools?
    Why not put sliders on.. then put as many as you need, using them where ever you need on the trailer?
    I have 10 on each side, plus another eight 2 inch ratchets. Seems accessive until you get that crazy load where you wish you had a few more.
    Better to have and not need... than to need and not have.
    Hurst
  4. CharlieK
    374
    4,454
    May 13, 2015
    Minnesota
    Sorry, should have clarified that... Chain spools.
  5. Ruthless
    Ruthless Road Train Member
    9,191
    91,271
    Aug 28, 2010
    The City.
    I like chain pulls out of the floor.some have said they prefer j hooks tho.
  6. Jumbo
    Jumbo Road Train Member
    3,669
    7,389
    Sep 4, 2009
    Appleton, Wisconsin
    Double spools add a little strength to the rub rail incase it gets bumped. Chain pulls and j channel are nice if the chains don't get tangled up and the channels are kept clean.
    barroll Thanks this.
  7. allan5oh
    allan5oh Road Train Member
    1,557
    556
    Jan 6, 2010
    Winnipeg, mb
    I like the Fontaine Revolution system.
  8. barroll
    barroll Road Train Member
    1,096
    544
    Nov 23, 2010
    Southwest Michigan
    Same. The turtles with chain pullouts are slick. I'd like to have them to keep chains tight to the load since they slide across the width of the trailer instead of the length like J-plates. The rub rails on them are seriously beefy, and I like how the rope hooks hold the strap hooks up until you get them tight.
  9. mtoo
    mtoo Road Train Member
    1,942
    4,526
    Jan 15, 2011
    Retired on bended knee
    I like a lot of things on the Revolution, I would never buy one because a flat bed needs wood nail strips. 3 of them. Those tail lights are going to suck in 10 years when your trying to hunt one down sitting behind a scale somewhere.
  10. mc8541ss
    mc8541ss Road Train Member
    1,467
    2,015
    Sep 22, 2007
    Lower Alabama
    I have a revolution and it sucks for over width loads that you want to use chains on. Especially with loads that are too low to the deck to pullout the chain pulls. Also with the way you secure the straps are not conducive to O/D loads.
    And with it being smooth underneath you have no way too add a piece of flat bar behind the winches to secure straps or chains too.
    Ruthless, skellr, MJ1657 and 1 other person Thank this.
  11. cgilliland
    cgilliland Medium Load Member
    321
    744
    Mar 13, 2017
    how do the turtles get into the track?
