Trailer Spring Brake Valve or ????
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by thecubantrucker, Apr 10, 2024.
  1. thecubantrucker
    thecubantrucker Light Load Member
    149
    92
    Jun 2, 2019
    How are you guys doing im running into an issue with my truck. When i set my trailer breaks the valve right under the cab that the air lines attach to it starts leaking air. I assumend something was wrong with the valve and i replaced it , it continued to do the same thing. When i took out the trailer line off i noticed that air was coming out of the emergency gland on the trailer when the brakes are set and that definitely isnt normal alongside that the button to make the pins go in/out in order to slide tandems isnt working as well like there is no pressure back there. When i press the valve inside cab in to air up the whole system it takes at least 20 seconds before i can drive it kind of feels like brakes dont release quickly. Im thinking is the trailer spring brake valve but need some opinions
  3. BoxCarKidd
    BoxCarKidd Road Train Member
    4,548
    6,641
    Aug 26, 2014
    I do not know anything about that pins program but would go straight to trailer park valve for air back feeding from the red trailer glad hand.
  4. BoxCarKidd
    4,548
    6,641
    Aug 26, 2014
    Air coming out of the red trailer or truck glad hand when disconnected and the park brake knobs are pulled out?
  5. thecubantrucker
    149
    92
    Jun 2, 2019
    When I set trailer brakes and disconnect the air line from truck to trailer air comes out of the trailer emergency Red gland where the airline goes until it drains the tanks in back pretty much
  6. thecubantrucker
    149
    92
    Jun 2, 2019
    Any other input like I mentioned when the knobs are out that I disconnect the air line air comes out trailer red emergy gland which it shouldn't do that is it that air brake spring valve??
  7. xsetra
    xsetra Road Train Member
    5,197
    7,147
    Aug 21, 2011
  8. kwswan
    kwswan Road Train Member
    2,028
    11,084
    Jul 26, 2009
    mcminnville,tn.
    I had a trailer doing the same thing. A new spring brake valve fixed it.
    BoxCarKidd Thanks this.
