Trailer air supply line pressure? I have a supply problem
Discussion in 'Volvo Forum' started by 86scotty, Jan 7, 2023.
  1. 86scotty
    86scotty Road Train Member
    4,908
    13,603
    Aug 27, 2017
    Appalachia
    I've had an occasional problem for awhile with my airbags and sliding tandem not working all the time, slow to build pressure. I replaced pressure protection valve and leveling valve in trailer today but still have a problem. I am getting pressure to everything in the trailer but not enough for everything to work reliably.
    Any idea what the pressure coming from the airlines at glad hands should be? I'm going to rig up a gauge to a glad hand tomorrow morning and test what I've got.
    I'm thinking the big valve on the firewall may be bad. I don't know what it's called. Has big green and red lines coming out of it, the green one goes straight under cab to trailer air line manifold at back wall. I'm thinking it's bad because if I supply air to the trailer and pull my red air line it just hisses, it does not pop closed on the dash as it should.
    D.Tibbitt Thanks this.
  3. loudtom
    loudtom Road Train Member
    1,717
    2,806
    Aug 26, 2016
    This part?
    If you've got another trailer you can test on, it would help narrow down if the problem is with the tractor or not. I've had a valve get plugged up with debris on the trailer tank that made it take forever to build enough air to release the trailer brakes.
  4. 86scotty
    4,908
    13,603
    Aug 27, 2017
    Appalachia
    That's the valve I am thinking of but he says that is the foot valve. I have no problem at all with brakes, I have a problem with air supply to the other things in the trailer (tandem release, tire inflation and airbags). I have replaced all valves in the trailer and checked and double checked them.
    Oh, by the way, I don't have any backfeed coming out of the foot valve like in the video.
    Any idea what valve I should check next?
    Also, I don't have a spare truck or trailer. I'd do both if I did, connect another truck to my trailer and another trailer to my truck.
  5. wichris
    wichris Road Train Member
    4,656
    9,727
    Jan 17, 2011
    Regulator on the air tank. That controls the leveling valve, air release, PSI, ect
    EverLuc Thanks this.
  6. 86scotty
    4,908
    13,603
    Aug 27, 2017
    Appalachia
    Just replaced and chased all that down yesterday. I am not getting enough pressure to supply that regulator/regulators. Or I should say I am but only intermittently.
  7. Ridgeline
    22,855
    126,585
    Check the pressure at the gland hand at the back of the cab and see what it is, if it is operating pressure, then look at a problem with the airline on the trailer. I had one which the driver ran over some junk on the road and and a piece of junk actually wedged up under the trailer and kinked the line, the mechanic had to replace that section of line.
    EDIT - didn't see the latest post, but it still is good info so I'll leave it.
    Siinman Thanks this.
  8. 86scotty
    4,908
    13,603
    Aug 27, 2017
    Appalachia
    @Ridgeline, thanks, I went over and over the trailer yesterday. I've got to rig up a gauge to test air pressure at glad hands. I do know that I might have two problems. If I supply air to the trailer (red knob in) and yank it loose my red knob on dash does not pop, just constant rush of air from red air line. I know this is a problem, I just don't know if it's the only problem.
    I'm going to rig up a gauge this morning. A friend also suggested taking my air compressor to the trailer and supplying trailer with it to see if everything there is working.
  9. 86scotty
    4,908
    13,603
    Aug 27, 2017
    Appalachia
    And also, what should supply line pressure at glad hands be, 120?
  10. wichris
    4,656
    9,727
    Jan 17, 2011
    Whatever your tractor tank pressure is.
    You replaced the emergency valve on the trailer?
  11. Cat sdp
    Cat sdp . .
    21,371
    76,824
    Apr 8, 2012
    Orion's Belt
    Is it a older trailer?Did you replace the diverter valve on the trailer ? Sometimes they get filled with crud and restrict air supply to trailer.Where the line goes back to the tandems and then all the other lines come out of the valve going to everything else at the back of the trailer.
