trailer tire rotation - important?
Discussion in 'Ask An Owner Operator' started by rollin coal, Jan 20, 2012.
  1. rollin coal
    rollin coal Road Train Member
    13,631
    28,013
    Mar 29, 2008
    TN
    The caps on my trailer all look to be wearing really good except for one. The left, rear, inside tire has a few dips in odd random places around the inside shoulder of it. It's not really all that bad, nothing that bothers me, but would it be a good idea to rotate them? And how specifically? Just move the ones on the back axle to the front? Or would it be better to criss-cross the Left rears with the Right fronts and vice versa? I always criss-cross my drives when they need rotating. Does it really matter on trailer tires? It's not like they have lug tread that you want to keep wearing evenly like on the drives, which criss-crossing does a good job smoothing out the wear on lugs.
  3. RedForeman
    RedForeman Momentum Conservationist
    4,875
    22,141
    Jan 30, 2011
    Cupping on the inside like that is likely a loose wheel bearing. Check the bearings and rotate that tire to another position. If it still cups it's probably a balance or bad casing problem.
  4. BAYOU
    BAYOU Road Train Member
    2,847
    1,592
    Sep 23, 2010
    Beaumont,Tx
    also could be shocks
  5. Crazy D
    Crazy D Medium Load Member
    493
    240
    Mar 18, 2011
    Homewood,IL
    Good question. Because the front axle on my spread both inside tires have cupping on the inside shoulder. Wondering whats going on with this.I figured it was because it was a spread.
  6. lumberhauler_oh
    lumberhauler_oh Bobtail Member
    29
    15
    Aug 25, 2008
    lima ohio
    wear like that on a spread is caused by the axle bushing
    had to replace mine put on new tires and no more wear
  7. BAYOU
    2,847
    1,592
    Sep 23, 2010
    Beaumont,Tx
    Your right I had to change mine a few years back I took it in to get a elinment and they said mine were wore alote I did that and shocks and get 100,000 pluse miles on my spread axle tires
  8. BigBadBill
    BigBadBill Bullishly Optimistic
    4,599
    4,439
    Oct 2, 2010
    Chattanooga, TN
    I'm getting same wear on spread. Are axle bushings hard to replace?
  9. BAYOU
    2,847
    1,592
    Sep 23, 2010
    Beaumont,Tx
    Not bad if you have a press I had to cut the head off two bolts they were seased up rust is a b-ch
