Trailer tires dillema
Discussion in 'Ask An Owner Operator' started by mp4694330, Jun 14, 2013.
  1. mp4694330
    mp4694330 Road Train Member
    1,530
    1,461
    Aug 30, 2010
    Chicagoland
    Hello!
    Have hard time to decide what to do with trailer tires (duals).
    Got new to me '07 Great Dane dry van.Great looking, I will PU it from shop today( needed few things repaired) but tires are in terrible condition, at least 4 need to be replaced right away.
    I stay in Midwest and Southeast, try to book lightest load possible but we all knows that some times heavy pays great too.
    So what to choose?
    I have OOIDA and Michelin National Account (Advantage) so Michelin's recaps or virgins?
    XTA Energy are going out, but still can get them,
    X Line Energy T backordered (I called few dealers but nobody knows when they will be available)
    Love Michelins but price...Are they worth it for their life span and rolling resistance?
    Any other recaps (Bandag)? Virgins?
    Still open to suggestions...
    Thanks, Mark
  3. Bakerman
    Bakerman Road Train Member
    4,663
    8,812
    Jan 27, 2013
    Phoenix, AZ
    I only use recaps on local trucks, never on an OTR truck/trailer.
  4. Allow Me.
    10,788
    12,674
    May 28, 2009
    Rancho Mirage, Ca.
    It's driver preference. You can argue re-caps/virgin rubber all day long. I would go with virgin rubber myself. Yes, more $$$, but peace of mind.
    mp4694330 and Container Hauler Thank this.
  5. Pound Puppy
    Pound Puppy Heavy Load Member
    974
    868
    May 31, 2010
    Amherst, OH
    Michelin just came out with an xda recap. Saw it at the truck show. They are gauranteeing 50% more tire life over competetors.
    mp4694330 Thanks this.
  6. mp4694330
    1,530
    1,461
    Aug 30, 2010
    Chicagoland
    XDA or XTA?
  7. TheDude1969
    TheDude1969 Heavy Load Member
    807
    823
    Jun 10, 2013
    Joliet, Il
    First and most important get them all on the same axle, and match the remaining pairs tread the best you can. So as to replace the two next worse at the same time/same side.. then the other pair shortly after.
    I cant tell one tire brand from the next, but this is not the season for fresh recaps... Call me old school, I like new recaps in October so the glue has all winter to settle. 80,000 + Fresh glue + old rubber on a toasty day don't end well.
  8. ‘Olhand
    ‘Olhand Cantankerous Crusty
    6,750
    16,653
    Jan 18, 2011
    Ive had very good luck with Sumitomo 710--the new 710SE has some very good numbers--also used them on steers--seen them online for about 365--but Im sure you can do better somewhere you do biz with on a set
    Just Sayin
  9. RedForeman
    RedForeman Momentum Conservationist
    4,875
    22,141
    Jan 30, 2011
    I've been running XT1 custom mold recaps on my reefers for the last two years. Zero blowouts and good wear. That is, virgin tires have not lasted any longer or done any better on my crappy old equipment. Use your own good casings or cherry pick ones that have no internal patches. I did get robbed, er I mean tire service, at the T/A in Tallulah LA for one of their Bandag trailer caps and it's holding up ok so far for a one-in-a-row success.
  10. Cowpie1
    Cowpie1 Road Train Member
    5,569
    4,652
    Nov 25, 2008
    Kellogg, IA
    If one watches tire inflations and other tire maintenance issues, recaps should not be any problem. I have run recaps on tractors for years and, even though I pull company trailers, have had them on trailers for years also. Now for the trailers, they make it easy in that they have those automatic inflation setups on the trailers so the tires always get proper inflation. Even a small leak will stayed aired up when running. It is only after you stop that it will leak down. Then I usually can catch it before any major tire blow out issues. I can't recall the last time I had a cap or virgin blow out on a trailer. Best guess is about 7 or 8 years ago. Never had a cap go out on a tractor. I know that many have had bad experiences with caps in the past, and are dead set against them. I'm ok with that. But in all fairness, almost every tire that blows, be it virgin or cap, the primary cause was improper inflation, running faster than the tire is rated for, or putting more load on than the tire was rated for. Yet, even though someone made the mistake, the tire gets the blame.
    Now, since I am on record as not having an issue with recaps, I do prefer the Michelin caps, and only on Michelin casings. Just me. I suppose others have had good results with other casings.
    MNdriver Thanks this.
  11. jbourque
    jbourque Heavy Load Member
    924
    553
    Oct 25, 2012
    south english iowa
    cowpie1 i agree with your post 100% good post, and yes oscar wilde did say that
