trailer tires
Discussion in 'Flatbed Trucking Forum' started by Bigrigmayo93, Jun 7, 2020.
  1. Bigrigmayo93
    Bigrigmayo93 Light Load Member
    132
    76
    Nov 28, 2016
    Chicago Illinois
    buying my first set of trailer tires
    recently purchased a 1998 48 ft benson fb
    front axle has 275/80r22.5 & rear axle has 295/75r22.5
    trailer recommends 11r22.5
    any recommendations on brand & size i should buy?
    i run midwest 300 mile radius from chicago
    i dont haul overweight or oversize
    pulling trailer with a w900
    any info is greatly appreciated!
  3. Frontman
    Frontman Light Load Member
    166
    151
    Apr 4, 2012
    One option for you is Love's TS sell the Double Coin TR100 for $2200 for 8. PLUS mount and balance cost if they do it.
    Rideandrepair and Bigrigmayo93 Thank this.
  4. TJB15
    TJB15 Light Load Member
    67
    115
    Apr 29, 2020
    Just my two cents if it was me and buying 8 I would go 11r if just doing 4 I would match what was still on the other axle. Never ran different sizes on same trailer so can't speak to that. Short/local with a spread is horrible on tires I wouldn't buy the most expensive but would try for good casings I could cap. I tend to use what I run for drives so I can cap them too and run out on trailer. Maybe I'm being cheap but my experience is that short haul spread axle flat absolutely eats tires.
  5. Bigrigmayo93
    132
    76
    Nov 28, 2016
    Chicago Illinois
    I’ve been hearing good things about those doublecoins! That’s not bad price at all!
    Rideandrepair, Frontman and 650cat425 Thank this.
  6. Bigrigmayo93
    132
    76
    Nov 28, 2016
    Chicago Illinois
    Cheap is good as long as you do it right & take care of those tires. I don’t see a problem with that.
    My rear axle at the moment has good year recaps
    Front axle has michelins & they have chunks missing. Due to u turns of course.
    That’s why I don’t see the point of spending so much money on tires.
    Rideandrepair Thanks this.
  7. beastr123
    beastr123 Road Train Member
    2,951
    24,203
    Jan 2, 2014
    Moose Jaw SK CAN
    you should know that those tires if same brand and model are 0.2% of being the same size
    Side by side Overlay
    295/75-22.5 275/80-22.5
    Diameter inches (mm) 39.92 (1014) 39.82 (1011.5)
    Width inches (mm) 11.61 (295) 10.83 (275)
    Circum. inches (mm) 125.42 (3185.57) 125.11 (3177.72) -(-7.85) -0.2%
    Sidewall Height inches (mm)
    8.71 (221.25) 8.66 (220) -0.05 (-1.25) -0.6%
    Revolutions per mile (km)
    505.2 (313.91) 506.45 (314.69)
  8. Bigrigmayo93
    132
    76
    Nov 28, 2016
    Chicago Illinois
    What I’m trying to find out is what size to buy if I’m buying all 8 new.
  9. beastr123
    2,951
    24,203
    Jan 2, 2014
    Moose Jaw SK CAN
    I would go with the 295/75-22.5 if they are easy to find in your area and are reasonably priced. They have a 0.79 inch wider footprint and should wear a wee bit slower than the 275/80-22.5 (maybe 1 to 3%). You can also run the wider tires at a slightly lower pressure to give a smoother ride if you want.
  10. Bigrigmayo93
    132
    76
    Nov 28, 2016
    Chicago Illinois
    Thanks for the info. I guess what’s available is what really matters
  11. beastr123
    2,951
    24,203
    Jan 2, 2014
    Moose Jaw SK CAN
    As a bonus you can keep the best 2 as spares.
