97 FLD. I have tails and markers but no turn signals or hazards on trailer. They work fine on the tractor. How do I troubleshoot. Thanks in advance.
trailer turn signals not working
Discussion in 'Freightliner Forum' started by mrkrausman, Oct 26, 2011.
bad wiring under cabine ore bad trailer - trucktor cabel.
Check your prongs in the trailer connection box.
Just use a screw driver (flat head) or a pocket knife to spread the prongs apart a little.
Often the prongs will lose connection by getting crimped together at the separation slit. -
On drivers.side firewall under hood, there are separate fuses and circuit breakers for trailer lights. Your tractor lights will work, yet trailer may not. Check those first.
Try this
I had the same problem and it was the pigtail prongs.
