trailers/load distrib.
Discussion in 'Questions From New Drivers' started by 2021DREAM, Mar 11, 2011.
  1. 2021DREAM
    2021DREAM Light Load Member
    112
    20
    Dec 31, 2010
    Sutherlin, Oregon
    Guys,
    What is the general purpose, objective and procedure for sliding the trailers axles back and forth; essentially for what reasons would it be needed to make this sort of adjustment?
    Educate me.
    Thanks,
    Mike (Wanna-be)
  3. chompi
    chompi Road Train Member
    5,653
    3,485
    Jun 21, 2008
    Deland, FL
    You move them back and forth to evenly distribute the weight of the trailer on the tandems and drives of the tractor and trailer. Legally you are allowed 80,000lbs including the weight of the tractor and trailer. However it must be no more than 34,000 on the tandems or drives whether the truck is underweight or not. If you have 37,000lbs on the drives of the tractor then you must slide the trailer tandems forward to take some of the weight off of the drives. The weight of the steer tires on the tractor is usually allowed to the specs of the individual tire manufacturers. If they say 23,000 then that is what you are allowed to carry on the steers. If your steers are overweight you can slide your fifth wheel.
    Hope that helps.
  4. ronin
    ronin Road Train Member
    2,928
    1,710
    Jul 22, 2008
    San Antonio, Texas
    Not trying to mess with you, but the steer tires can only hold whatever the vehicle manufacturer puts on the door plate, regardless of the type of tires used. 658.17 states the steer axle can legally weigh up to 20,000 lbs, or the manufacturer's limit, whichever is less.
  5. jakebrake12
    jakebrake12 Road Train Member
    1,576
    1,047
    Feb 15, 2008
    I95
    Question for you drivers familiar with sliding tandems..
    What's a general rule of thumb for how much weight you transfer per hole on sliding tandems - is there a general amount? The reason I ask is I have to scale a lot of our long-box loads and have never really done it before - only familiar with scaling spread axles and sets..
    Thanks..
  6. formertaxidriver
    formertaxidriver Heavy Load Member
    767
    375
    Jan 22, 2008
    Aiea, HI
    Depends on the brand of the trailer. I've experienced between 250-400 lbs. per hole.
    jakebrake12 Thanks this.
  7. Lilbit
    Lilbit Road Train Member
    16,583
    12,233
    Aug 4, 2008
    Let me check my logbook
    Generally it is about 250 lbs per hole, but that will depend on how many holes are available, so it will vary. There is a bit more to it than that, but that is a basic rough number. I'm getting this info from my hubby as I type.
    Wargames and jakebrake12 Thank this.
  8. jakebrake12
    1,576
    1,047
    Feb 15, 2008
    I95
    I suppose the variable in weight per hole depends on where the weight is in the trailer? I'm guessing you'll notice the most weight per hole if the weight is evenly spread throughout the trailer?
    For whatever reason we overload the rear an awful lot..
  9. Lilbit
    16,583
    12,233
    Aug 4, 2008
    Not really. The weight per hole is the same on your wagon no matter how the trailer is loaded.
  10. jakebrake12
    1,576
    1,047
    Feb 15, 2008
    I95
    Thank you everyone and I'll keep the 250-400 range in mind..
    I'll have to play around with it a little when I get a chance.. Can be hard to scale a trailer with a yard truck anyway but we at least try to get a ballpark idea with anything over 35,000 total..
    Lilbit Thanks this.
  11. scottchris71
    scottchris71 Light Load Member
    165
    49
    Nov 18, 2010
    iowa
    Just to add alittle here...the 250 per hole is a good starting point...but really depends how long your slider rails are and how far apart your holes are..I have seen great dane trls around 600 a hole before
    jakebrake12 and formertaxidriver Thank this.
