tranny, slave cylinder problems
Discussion in 'Trucks [ Eighteen Wheelers ]' started by grimesjm1, Jul 9, 2010.
  1. grimesjm1
    grimesjm1 Medium Load Member
    375
    228
    Nov 5, 2008
    Kensington,OH
    2004 Volvo 670. ISX engine with straight 10. Clutch has 50,000 miles on it still looks good. Tranny started slipping a few weeks ago. today the clutch master cylinder went dry twice. when i refill it does fine for awhile. i cant see where its leaking from. could the slave cylinder be leakin on clutch and causing it to slip and not show signs of wear?
    also if it is the slave cylinder, can that be swapped out without dropping the tranny? thanks guys!
  3. Smalltruck
    Smalltruck Light Load Member
    141
    68
    Jul 3, 2010
    Elko, MN
    The slave cylinder is under the clutch. So gravity won't let the fluid leak up. Yes you can change the slave without pulling the transmission. There's a line bundle under the left floorboard that has lots of airlines and buried in that is the line for the clutch. Make sure the leak isn't hiding in there.
    Have you checked the clutch adjustment? And do you know how? Volvo has a different way to check free travel. The spec is 1/2 inch clearance between the face of the bearing and the clutch brake surface. You need a tool to do a good job of checking this. Take a welding rod and weld a 5/16ths nut to it (wrench size 1/2 inch) this makes it easy to stick up in the hole. Your tool should just slide up in between easily without a lot of play.
    Second- when you did the clutch, if the yoke and linkage was not replaced make sure its still tight because that will screw up a good clutch fast. Warning those parts will cost you about $600 or more....Volvo only
  4. grimesjm1
    375
    228
    Nov 5, 2008
    Kensington,OH
    thx. slave was leaking, had a bunch of dirty fluid and other gunk in the bell. replaced it in about half an hour. too lazy to test drive it till monday but hopefully that clears up my slipping too
