Transfer Dump problems with remote backup using starter to back truck up to trailer
Discussion in 'Kenworth Forum' started by sandslinger, Apr 9, 2014.
  1. sandslinger
    sandslinger Bobtail Member
    I have an 03 t800 transfer dump truck. to hook up to trailer we (transfers) put it in reverse with the key off and press a button at the back of the truck that engages the starter and backs the truck into the draw bar thus locking the pintle hook. the problem is that it acts like I have a low battery and won't back up. I have replaced the batteries, battery cables starter relay and 135 amp breaker and the starter and still it acts like low batteries. It will almost always start right up with the ignition switch (in cab) but if I put it in gear rrrh and no movement. I am wondering if the motor it self is somehow the problem ?. I've heard of injectors dribbling causing it to hydraulic, but this happens seconds after shutting the motor off with the trans in reverse and attempting to back it up with the remote starter engagement button.Then I can jump in the cab and it will start righ up I've also tried the cab ignition switch with it in reverse and it does the same thing rrrh and no movement. And no the park brake is not on. any body have any ideas, it would be greatly appreciated. Again everything is new less than 2 weeks, batteries, cables, starter relay (in battery box) 135 amp breaker and the starter replaced today 04/08/14. The reason I replaced the starter last is I just replaced it a few months ago and that didn't change anything. when the ignition is shut off the remote starter works independently of the computer as far as I know it is as isolated circuit and I have replaced everything in it. Frustrated.
  3. Boardhauler
    Boardhauler Road Train Member
    1,736
    3,703
    Dec 21, 2008
    Ballin' in it for Shakey
    If you use the remote switch with it in a forward gear, does it do the same thing? If so it seems like it has to be in the circuit for the remote switch since it starts with the ignition switch, which kind of indicates that it's not in the batteries, cables or starter.
  4. jameslawton
    jameslawton Light Load Member
    257
    65
    May 1, 2013
    Tulsa OK
    Might check for a brake sticking as well
  5. JW Trucking
    JW Trucking Bobtail Member
    34
    Mar 14, 2011
    MT
    What brand of starter did you use?? Have a few transfers. Also what gearing is in the starter this changes things as well.
  6. mq1982
    mq1982 Bobtail Member
    Is there a separate wire that leads from the remote start to the starter and the ignition maybe? Maybe and bad connection in the remote start to the starter ?...might be irrelevant but thought I'd try and help. I still have lots to learn about transfer.
  7. mitchtazz
    mitchtazz Road Train Member
    1,826
    503
    Sep 6, 2009
    Lake Wales, Fl
    try doing it in a forward gear and see if the starter still drags, if so then the starter might not be geared low enough, if not then it'll have to be an issue between your starter and the reverse gear in your transmission.. maybe reverse is geared higher then your 1st/ granny gear.
