Transmission / Axle Combo?
Discussion in 'International Forum' started by Prodirt6000, Apr 30, 2019.
  1. Prodirt6000
    Prodirt6000 Bobtail Member
    33
    Aug 30, 2015
    Hello all I have a rookie question. Our truck has a 13 speed and 3.70 rears on our 89 International 9300. It’s almost impossible to get going in Low when loaded on any kind of slight uphill incline. The truck is a 3406B and has tons of power, but it’s just hard to get started, even when going in reverse.
    What’s the best way to fix this? Swap out for rears like 4:10 or something similar? Someone said all transmissions are the same. A 13 speed is a 13 speed, an 18 is an 18 etc and they don’t have different ratios. Is that true? Also should mention this has the horseshoe shift pattern, 3rd and 4th are opposite if that says anything?
    I’ve drove a lot of trucks but this 9300 is the most difficult truck I have ever drove. I see road trucks for sale with 3:55 rears and they are hauling 80-90,000 lbs and have no issues getting going from a dead stop on a hill. I just don’t understand.
    Thanks
  3. Prodirt6000
    33
    Aug 30, 2015
    Also, were cruising about 60-65 mph at 1800 rpms. We still have 3rd and 4th gear on the high side untouched.... Its an agriculture truck but used to be a fuel and lube truck before it got to us.
  4. Prodirt6000
    33
    Aug 30, 2015
    I took model number off transmission.
    RTLO-14713A
    Thanks for any and all help
  5. BigCam9670
    BigCam9670 Medium Load Member
    418
    4,593
    Jun 12, 2012
    Hudson, NY
    What is the tire size on the drive axles? Even with tall 24.5 you shouldn't have an issue taking off from a stop in low gear at 80k gross or under with that transmission. 60-65 @ 1800 sounds about right in direct which would be the high side of 7th gear, assuming you have tall 24.5s. 13s and 18s can have different ratios , the letter at the end, in your case "A" denotes that.
    Is the truck jumping around when you are trying to take off? Almost sounds like more of a clutch or linkage issue to me.
  6. starmac
    starmac Road Train Member
    6,639
    12,528
    Apr 11, 2019
    Fairbanks Ak
    That is probably my all time favorite gears for on and off road use, with tall rubber. I am thinking something else id going on.
    What exactly is it doing, maybe busted motor mount or something. Pump needs some work or timing., etc.
  7. REO6205
    REO6205 Road Train Member
    13,168
    60,500
    Feb 15, 2014
    California.
    Are you sure of the rear-end ratio?
  8. AModelCat
    164,668
    With all those gears left at highway speeds I'd be asking the same question.
    REO6205 Thanks this.
  9. KVB
    KVB Heavy Load Member
    877
    2,875
    Jun 30, 2012
    Are you sure about the RTLO-14713A?
    Was the transmission replaced at some point, and the old cover used on the newer transmission?
    As far as I know RTLO-14713A should not have the horsehoe shift pattern, if it has the original shift bar housing (top cover).
    What tire size on the truck?
    In which gear exactly are you when running 60-65 @1800.
    3rd and 4th untouched seems to indicate you still have 4 gears left (3L, 3H, 4L and 4H)?
    Seems very unlikely, with 3.7 rears, even if the truck would have an RTOO-14613 (which has 3 overdrives, RTLO-14713A only has 2, but it would explain the reverse shift pattern)
  10. Prodirt6000
    33
    Aug 30, 2015
    Hi everyone thanks for all the repsonses.
    So no, I dont know for sure if the transmission and ratio are all correct. I am just going by the steel stamped tags on the housings. It does say Reman, as well. I did a little research last night and found each ratio for each gear for that transmission. Then, I found a calculator for tire size, rear end ratio, RPM and transmission ratio. From my calculations those ratios are correct when I used my GPS to track my speed this monring.
    Attached is my chart. Each colored area is a gear, with that transmission ratio, and calculated MPH. The first set of numbers is with our 3.70 axles, then I did one if we had 4.11, or 4.88. Just wanted to compare speeds. The highest gear we get to now is high side 2nd, or 6th, with the red splitter forward. Ratio of 1.38 at 48-49 mph. (Our spedo was off when I mentioned it in my previous post).
    Tire size is 700x40x22.5. 46.1" tall tire I believe. Flotation tires.
    As far as the clutch, linkage, and engine mounts I have read before that mounts could be bad. Whats best way of checking all these? Good diesel mechanic? When I accelerate after each shift, I can hear the RPM's increase followed by something finally engaging. Its usually about a 1/2 second delay. Also it usually lurches or lunges ahead. Extremely annoying! Also, at a dead stop when empty, you really have to concentrate to let RPMs out slowly to get truck to go ahead smoothly. I feel like its the first time I've ever used a clutch each time I drive it. Also, the shifter lever does no lunge at all during acceleration.
    Thanks alot really hoping to get this thing figured out!
  11. Prodirt6000
    33
    Aug 30, 2015
    Well I have been looking a little more into it. I used an 18 speed for an example ( RTLO-18918B) as well with my 3.70 rears. In Low gear splitter back at 1800 RPMs Id be traveling a speed of 4.63 MPH, 0.79 MPH slower than my current set up. We are trying to price out what is cheaper, just change out tandems or go with different transmission.
    I'm pretty confident engine mounts are good, shifter does not move at all during acceleration. Since we only travel 65 tops with the truck seems like we should just throw a set of 4.88 in the back. I found some about 5 hours away for $2,500 full lockers. Is that a good price?
    Still looking for any insight on slop I feel after each shift, most likely it would be ring and pinion or similar in there.
    Thanks
