Transmission choices
Discussion in 'Experienced Truckers' Advice' started by TNSquire, Oct 5, 2021.
  1. TNSquire
    TNSquire Medium Load Member
    571
    1,967
    Oct 13, 2016
    Decatur, TN
    Friends, I'm beginning the process for going Owner op, and would like your thoughts on a couple things.
    I figure I'm about a year out, building capital and other things that are necessary for success.
    I've read hundreds of threads on how to succeed, and what the causes of failure are, and am planning accordingly as best I can.
    I run local tanker, and expect I'll stay in the local/ regional market, given the demand for it.
    One question that has come up is, when choosing a truck, what motor/ transmission combo would be ideal?
    I'm most familiar with a 10 speed 8LL, but drove an 18 and loved it.
    What I don't know is how that impacts driveability and durability while pulling a smooth bore tanker.
    I'm not totally sold on automatic, but not opposed either.
    I have plenty of time to wait for the ideal truck to come across the lot.
    What's your insight on this?
    Thanks in advance!
  3. Arctic_fox
    4,559
    25,968
    Sep 16, 2016
    Honestly i would go with an 18 speed or 13 speed at a minimum as an O/O. They give a lot more flexability then a 10 speed or even a auto in my opinion. As an O/O you never know when you will be kicked to the curb for a company driver or need to leave once work dries up and have no clue what may be coming down the pipe later. Having an 18 and say 46k rears gives you more options without adding a lot of weight. Say your tanker job goes tits up and you find a job hauling overweight flatbed loads for instance. Having an 18 speed gives you the option to grab those loads and the lower gears to get and keep it moving much more easily. While a 10 speed or auto might work here an 18 will be far more user freindly.
    That said in terms of durability and reliability you wont notice a huge diffrence between a 10 13 or 18, or even an auto. You will see a slight to moderate mileage bump with an auto though. That said considerimg the current state of computer chips and companys taking a "if its even somewhat in some shape close to a pass sell it" stance on QC atm....well i sure as hell wouldnt feel safe letting a computer dictate how to shift my rig for me.....especially loaded on a hill.
  4. TNSquire
    571
    1,967
    Oct 13, 2016
    Decatur, TN
    @Arctic_fox
    Solid logic there.
    Makes a lot of sense having a power unit that's versatile and overly capable.
    I do have the option of hauling logs for local loggers, of which I have an excellent network to find loads. The 18 would make that cake work. Them boys like to overload every time.
    I do find that I'm most interested in the difficult types of loads... each one is different, presents unique challenges, and brings a satisfaction of success when I deliver it safely and on time.
    Plenty of equipment in the area that needs moving too...35 ton rgn would get worn out once word gets out I'm for hire.
  5. skellr
    skellr Road Train Member
    8,735
    12,187
    Jul 17, 2011
    The Village, Portmeirion
    IDK.
    I'm running an 18spd hauling 129k and I mostly drive it like a nine speed. I could split the gears and maybe top a hill at 3-4mph faster but it really sucks the fuel doing that. (keeping the rpm between 1700-1900 rpm for the peak HP that is)
    A 10 spd would probably fit the bill as a nice in between.
    I pull it up a couple of 8% grades and there isn't much difference between 18 and 9. Maybe on those annoying long gradual incline grades and extra gear could be a "perk", but it's isn't a game changer, IMO.
  6. LTL Bull
    LTL Bull Road Train Member
    1,561
    6,569
    Mar 12, 2020
    Auto shifts are computer controlled. Anything that has a computer involved I try very hard to stay away from. Not much choice on the motor having a computer. Having pulled smoothbore general chemical and milk with both auto shift and standard I would stay very far away from the auto shift. R&L has gone mostly to auto shift and there were lots of issues with the. Though it did seem to be a hit and miss across different makes and models
    TNSquire Thanks this.
  7. Ridgeline
    22,757
    124,209
    18 speed is the best.
  8. Last Call
    Last Call Road Train Member
    7,568
    45,914
    Mar 15, 2021
    Buy a 18 speed for the same reasons Artic Fox stated if you don't need all 18 .drive it like a 9 speed then.. I love my 18 speed wouldn't have it any other way ... its just like the terminology ..."Friends with Benefits".... they're there when you need them ...there're not when you don't
    TNSquire and LTL Bull Thank this.
  9. mustang190
    mustang190 Road Train Member
    2,896
    6,261
    Jan 18, 2011
    Florida Panhandle
    A automatic in truck pulling a tanker, especially a smoothbore will beat you and your truck to death. At least with a manual you can somewhat control the surge.
    SQ609, w9l and TNSquire Thank this.
  10. kylefitzy
    kylefitzy Road Train Member
    4,755
    19,811
    Aug 12, 2007
    Kansas city,Mo
    A 13 will do just fine. Manual over an “auto” any day. I have an 18, never really seen the need to split the lower gears. Usually just split the top two when loaded.
    Diesel Dave Thanks this.
  11. TripleSix
    133,753
    The thing that I like about the 13s and 18s is that in low traction conditions, the 8 gears on the top give a driver worlds more options and control. Feel the tires spin, drop a gear. Repeat until you get to the top of the incline.
    kwswan and AModelCat Thank this.
