Transmission lines wet
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by earnies2, Jun 16, 2021.
  1. earnies2
    earnies2 Medium Load Member
    691
    282
    May 17, 2012
    Dedham, MA.
    The other day I noticed my transmission cooling lines are wet not leaking but wet. So I need to change them.
    I was wondering if adding a second cooler like the one behind the cab on the frame on Freightliners would help?
    I belive u have the cooler. So I would come out of the trany to the cooler behind the cab then to the cooler in front of the radiator then back to the transmission. It would only cost me the extra lines and fittings.
    Would it be worth it?
  3. lester
    2,959
    8,098
    Jan 2, 2012
    NW, Iowa
    Is your tranny running that warm that you think you need another cooler?
    Roger McG and earnies2 Thank this.
  4. earnies2
    691
    282
    May 17, 2012
    Dedham, MA.
    No its not running hot just thinking that cooler would be better...
  5. Mike250rs
    Mike250rs Heavy Load Member
    881
    7,082
    Sep 24, 2019
    Raleigh, NC
    If its staying at temp.. why add more places for things to leak later?
    earnies2, AModelCat and lester Thank this.
  6. lester
    2,959
    8,098
    Jan 2, 2012
    NW, Iowa
    I wouldn't add a cooler than
    earnies2 and AModelCat Thank this.
  7. earnies2
    691
    282
    May 17, 2012
    Dedham, MA.
    Just thinking that if it was to run cooler it would benefit the trany and longevity.
  8. Roger McG
    Roger McG Light Load Member
    165
    198
    Oct 22, 2016
    western mass
    Gotta remember 1 thing if the oem thought it needed a second cooler they would have added 1 from the factory. By the time you go to the back to go to the front you add capacity to the lube system.
    earnies2 and Last Call Thank this.
  9. Last Call
    Last Call Road Train Member
    7,568
    45,914
    Mar 15, 2021
    If it ain't broke...Don't fix it
    Final Drive, Roger McG and earnies2 Thank this.
  10. AModelCat
    165,696
    There's really nothing inside a typical manual/automated manual transmission that would really see any benefit from a slight reduction in oil temperature. Its all gears and bearings. I don't think you'd see a gain in life from the range synchro either.
    Now if we're talking an Alison automatic then a little extra cooling capacity wouldn't be terrible. Those are true autos with torque converters and clutch groups. They don't care much for high heat.
    Dave_in_AZ and earnies2 Thank this.
  11. earnies2
    691
    282
    May 17, 2012
    Dedham, MA.
    Added capacity is good just like a bypass filter adds capacity. Do you think a second cooler will will double the BTU's of the trany cooler cooling?
