transmission making noises
Discussion in 'Questions From New Drivers' started by 77fib77, Apr 25, 2013.
  1. 77fib77
    77fib77 Road Train Member
    11,747
    77,831
    Jul 7, 2010
    St Louis
    Ok clutch in its quiet, clutch out sounds like a gravel mixer. Trans got hot and pulled over. Lost fifth and tenth gear. What is broke?
  3. RAGE 18
    RAGE 18 Road Train Member
    1,529
    941
    Jan 31, 2011
    GOLD£N☆STAT£
    Ur fifth gear and tenth gear. See if you can make it to a shop. The fat lady has sung her song on that trans.
  4. 77fib77
    11,747
    77,831
    Jul 7, 2010
    St Louis
    Yeah its cooked. I called the owner when i noticed tenth go out. He told me to keep going. Ten miles later, eight started to go. Now the whole transmission sounds like rock crusher. Transmission cooling lime blew.
  5. eeb
    eeb Heavy Load Member
    731
    268
    Mar 24, 2013
    Ya, they all do that.
  6. BigJim1937
    BigJim1937 Medium Load Member
    303
    135
    Mar 27, 2012
    Fargo,ND
    Could be a bearing packup and then blew up, or some teeth came off the 5/10 gear, most likely you lost some teeth. They then go about taking little pieces off the other gears, then your cooler line gets plugged and the pump keeps on pumping till the line goes. As long as the trans case isnt damaged it may be able to be fixed depending on what the bearing supports look like.
