Transmission not going into High Gear
Discussion in 'Trucks [ Eighteen Wheelers ]' started by firecatf7333, Oct 30, 2019.
  1. firecatf7333
    firecatf7333 Light Load Member
    178
    59
    Oct 28, 2012
    2007 freightliner century 10 speed eaton manual trans
    The past 2 weeks I've noticed a few second lag when flipping the high range switch.. I can hear the air and it sounds sluggish and not normal. Today it wouldn't go into High Gear until 10 minutes after flipping the switch. I have to move the shifter side to side and it will go in high gear but it has the same air lag delay. Its not instant like it used to be.
    I drained the air tanks which were full of water a few days ago.
  3. poppapump1332
    poppapump1332 Road Train Member
    2,986
    2,464
    Jan 2, 2010
    birdsboro,pa
    sounds like something in the back of trans is bad
  4. BoxCarKidd
    BoxCarKidd Road Train Member
    4,555
    6,643
    Aug 26, 2014
    Transmission model number?
    spsauerland Thanks this.
  5. firecatf7333
    178
    59
    Oct 28, 2012
    I think its an air issue.. The Hi Low shifter won't do anything until I have at least 100 pounds of air. I used to move it with much less than that. Once I hear the "air click" everything shifts fine.
    Where do i get the transmission model #?
  6. AModelCat
    165,051
    There should be a filter in the air regulator. Typically its on the back of the transmission, kinda beside the output yoke. When it clogs up, you get a lazy low-high shift.
  7. firecatf7333
    178
    59
    Oct 28, 2012
    Is there a slave valve ?
