Transmission problems only 9th gear working
Discussion in 'International Forum' started by gabton-tankers, Feb 18, 2014.
  1. gabton-tankers
    gabton-tankers Light Load Member
    92
    6
    Feb 11, 2014
    What is usually the life of these transmissions when used above average? Mine currently had 650k miles until it gave up? What is the proper way to do preventive maintenance on the transmissions?
  3. Heavyd
    Heavyd Road Train Member
    7,828
    6,277
    Feb 4, 2009
    If the transmission is properly operated you can get 2 million. It all depends on how it is used or abused.
    I think Eaton usually recommends about 500,000 miles with synthetic lube. As far as preventative maintenance, all you do is simply check the oil level/quality every service. Some trucks have tranny coolers, so with those you would just inspect the cooler and lines for leaks and condition.
    Here is a link for some more info;
    http://www.roadranger.com/rr/ProductsServices/ProductsbyCategory/Lubricants/index.htm
    DoneYourWay Thanks this.
  4. baha
    baha Road Train Member
    4,137
    2,837
    Jul 25, 2013
    ga
    CK. if shifter is broken in top plate of trans.
  5. gabton-tankers
    92
    6
    Feb 11, 2014
    Verdict: we removed transmission and found more problems. Transmission cooler and PTO is filled with metal shavings from the transmission grinding its gears. The problem was the transmission did not have much oil in it and that caused it to give out. In addition, my driver drove the truck on 9th gear and end up destroying the clutch. I have to buy new clutch as well and resurface the flywheel. All this cost an arm and a leg.
  6. Heavyd
    7,828
    6,277
    Feb 4, 2009
    That sucks, sorry to hear all that. I would have been replacing the clutch anyway since the trans was out.
  7. gabton-tankers
    92
    6
    Feb 11, 2014
    Yeah, its pretty horrible. I kinda wish that the driver have some type of a 6th sense to feel these problems and get it to my attention before it will cost thousands of dollars.
