Transmission swap
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by ricinindy, Aug 2, 2018.
  1. ricinindy
    ricinindy Bobtail Member
    10
    Mar 30, 2011
    Indianapolis, Indiana
    I recently lost the transmission in my 95 Kenworth. Swapped my super 10 to a 13 speed Eaton. Now my speedometer and cruise doesn't work? They tested the wires from the ecm to the speedometer sensor and other sensor and it has power but couldn't test the other side because they needed the wiring diagram.
    I have a 60 series detroit.
    The speedometer does come up between 2 to 5 mph at 55 to 60 mph. So either I have a short/ bad wire or the dip switch settings need changed because of the different transmission? Or maybe the parameters in the ECM need changed? I haven't a clue and it's sitting at Clarke Diesel in Indy now and they have been waiting for 3 day's to hear from Detroit. If anyone has dealt with this issue please help!
  3. Superhauler
    Superhauler TEACHER OF MEN
    12,209
    100,735
    Jan 30, 2010
    keep stroking.
    Did you change the pulse ring behind yoke as well ? If not it may have different spaces between the pulse nubs than what your other trans had or may not even have one on it.
    Oxbow, Tug Toy, Hulld and 1 other person Thank this.
  4. ricinindy
    10
    Mar 30, 2011
    It has a tone ring but whether or not they are the same I have no clue.
    Oxbow Thanks this.
  5. Superhauler
    12,209
    100,735
    Jan 30, 2010
    keep stroking.
    Did you adjust the sensor at the correct gap ? I screw mine in till it touches then back it off half turn.
    Oxbow Thanks this.
  6. ricinindy
    10
    Mar 30, 2011
    Yep. Lol.
  7. AModelCat
    164,678
    Did you re-use the speed sensors off your original super 10 or just plugged in to what was on the 13?
    Oxbow Thanks this.
  8. BoxCarKidd
    BoxCarKidd Road Train Member
    4,548
    6,641
    Aug 26, 2014
    I saw something like that once. The tone ring could be turned with a screwdriver through the sensor hole. Problem solved by tightening yoke nut.
  9. Rideandrepair
    17,561
    56,894
    Aug 8, 2015
    Mine has 2 sensors had to change both odometer quit now I guess I need new speedo.Been broke for 4 yrs!!! Don’t need odometer any more!
