Transmission temp gauge
Discussion in 'International Forum' started by 1Logger1, Oct 4, 2025.
  1. 1Logger1
    1Logger1 Bobtail Member
    7
    Mar 12, 2025
    i bought a used 2020 520 HX, with a Eaton fuller RTLO-18918B, my trans temp gauge will trip the audible alarm and the gauge hand will bottom out on the dial shortly into my day of driving. I replaced the sensor on the lower passenger side of the trans. This did not fix the issue, is there another temp sensor?
  3. Lazer
    Lazer Road Train Member
    1,848
    2,978
    Jan 22, 2017
    Are sure the transmission is not low on lubricant? And, just as important is the correct lubricant in the transmission? Is there a ‘transmission cooler’?
  4. Big Road Skateboard
    7,096
    40,268
    May 2, 2021
    Maybe it's getting very hot?
  5. 062
    062 Road Train Member
    6,328
    33,969
    Oct 20, 2013
    Bottom out? Is that zero or in the red?
    Heavyd Thanks this.
  6. 1Logger1
    7
    Mar 12, 2025
    It was full when i drained the tranny, i replaced the oil and the “sensor” with Eaton fuller synthetic Manuel trans oil 50#
  7. wore out
    wore out Numbered Classic
    17,324
    215,116
    Jun 5, 2013
    CHASIN THE DEVIL'S HERD
    Most times when one’s hot you can smell it. A faint oil smell. Worse case fall under there and see if you can touch it. My money is on you cant
  8. 1Logger1
    7
    Mar 12, 2025
    First I appreciate the response, i do have a little common sense and Of coarse i put a hand to the side case, cool to the touch.
  9. AModelCat
    164,645
    If by pegged you mean it went to the 6 o'clock position then I believe you've got a CAN issue. I seem to recall the gauges do that on Internationals when they have a CAN communication problem.
  10. Heavyd
    Heavyd Road Train Member
    7,826
    6,276
    Feb 4, 2009
    This is a basic hardwired sensor with a manual trans. Remove the cluster, and look for wire A31, 18 gauge grey wire. This eventually goes to the sensor. With the circuit either shorted, or open will cause this. I don't have temp to resistance chart for that sensor, but you can unplug it and measure the resistance it has. Then A31 at the cluster should have that same resistance to ground. If your meter reads OL, then the circuit is open somewhere. If it measures low to no resistance to ground, then it is shorted somewhere.
    wore out, AModelCat and 062 Thank this.
