Transmission
Discussion in 'Freightliner Forum' started by Trell44, Mar 28, 2022.
  1. Trell44
    Trell44 Bobtail Member
    4
    Aug 24, 2021
    I have a 10 speed meritor rock well transmission soleniods noise is leaking from the cylinder range housing what's going on
  3. Flat Earth Trucker
    4,324
    16,671
    Nov 19, 2018
    @AModelCat
    I did not know noise could leak, but ok.
  4. kranky1
    kranky1 Road Train Member
    2,253
    8,855
    Sep 16, 2015
    Ontario, Canada
    You only have 2 choices. Either the air supply line to the spitter valve is leaking, or it’s time for a valve. Take the trim cover off the valve and see if it’s leaking from a hose or fitting at the bottom of the valve where the air lines go in, or leaking through the valve exhaust port. If it’s coming from the exhaust port the valve is bad.
  5. kranky1
    2,253
    8,855
    Sep 16, 2015
    Ontario, Canada
    If it’s leaking from the shift solenoid at the back of the transmission it’s the same deal. If the lines and fittings are ok the the solenoid itself is leaking internally.
  6. AModelCat
    164,924
    Never seen a Meritor transmission. Apparently they're electric over air.
    I think @nasriza is the guru on those transmissions.
