Travel INTO Canada
Discussion in 'Ask An Owner Operator' started by Hanadarko, Jul 25, 2012.
  1. Hanadarko
    Hanadarko Independent Owner/Operator
    2,971
    935
    Oct 1, 2009
    Midwest
    I'm looking at taking some freight on recurring runs up into Canada and returning empty.
    I am starting to read up on the permits required (like Ontario's CVOR) and restrictions.
    My rig has a 266" WB but it is older than a 2003, so the WB is grandfathered in - at least for now.
    I already had my passport, TWIC as well as my FAST cards, so I think I'm good there.
    But, I am looking for someone on here that has (or still does) run into Canada that can help point me in the right direction.
    Even a recommendation to a permit company that "does it all" would be fine too.
    The few permit companies I called either gave me whishy-washy answers or were juggling 2-3 calls at the same time as mine.
    OOIDA wasn't much help, which was actually surprising to me.
    :biggrin_25521:
  3. RickG
    RickG Road Train Member
    12,812
    6,137
    Jul 22, 2008
    Owensboro , KY
  4. FLATBED
    FLATBED Road Train Member
    The wheelbase restrictions in Ontario is being revised ( longer ) to allow for APU's , Livingston is 1 of the better brokerages and good service
  5. Hanadarko
    2,971
    935
    Oct 1, 2009
    Midwest
    Well...I dont think they dont seem to do permits?? - I dont need a broker per se, but i need someone to help me with the paperwork and permits.
    windsmith Thanks this.
  6. windsmith
    windsmith Road Train Member
    7,296
    6,032
    Sep 2, 2011
    NEPA
    I'm looking for the same info. Run northeast a lot and want the flexibility of getting some of those good rates going in and out of Canada.
    Hanadarko Thanks this.
  7. Hanadarko
    2,971
    935
    Oct 1, 2009
    Midwest
    You bet!
    So far, here is what I have learned...costs may vary based on doing it yourself vs a permit company:
    -Ontario requires:
    IRP/IFTA
    CVOR: $250/yr - takes 15 days to process
    -Quebec requires the following:
    IRP/IFTA
    Safety permit form
    NI # (no idea what that is)
    Power of Atty from someone with a Quebec mailing address
    -SASKATCHEWAN
    Nothing required beyond IRP/IFTA
    So far, doing the math...to get setup for Ontario and Quebec is close to $1k out of pocket.
    Naturally that can be made up on the many loads up to there. Just expect to come back deadhead.
    There is virtually #### coming back out of there...
    But at the high rates, you can easily afford to do that.
    Oh...then there is a PARS (pre-arrival-review system) and PAPS (Pre-arrival Processing System). One is for import to CA and one is if your hauling export.
    Many guys wont or cant deal with these regulations...but I think its worth some investigation.
    We also seem to need a 4 digit Canada code:
    http://www.cbsa-asfc.gc.ca/services/carrier-transporteur/codes-eng.html
    :biggrin_25519:
  8. FLATBED
  9. newskate
    newskate Bobtail Member
    42
    13
    Jun 13, 2012
    dont you need a scac number?
  10. Hanadarko
    2,971
    935
    Oct 1, 2009
    Midwest
    I believe so. I have an SCAC number already though...
  11. newskate
    42
    13
    Jun 13, 2012
    what did the scac number cost?
